09-19-2017, 11:27 AM | #1 |
Drives: ss beast Join Date: Sep 2013
Smith brothers or btr TRUNNION KIT
What's going on guys I am upgrading my trunnion just wanna know which is better what's the pros and cons Between both of them thanks for the help
09-21-2017, 07:23 PM | #2 |
Any help
09-21-2017, 07:54 PM | #3 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
any bronze bushing kit will be an upgrade...I used these http://www.ebay.com/itm/Powell-Cams-...xYQkNl&vxp=mtr and so far they work awesome..plus save a few $$$$...good luck!
09-21-2017, 07:59 PM | #4 |
Nice but are they better then the Needle bearings
09-21-2017, 09:18 PM | #5 |
absolutely...
09-21-2017, 11:44 PM | #6 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
I went with the Straub bronze trunion upgrade kit and have no regrets!
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
09-22-2017, 12:22 AM | #7 |
Drives: 2012 SS/RS MN6 Join Date: Mar 2016
Got mine from Summit Racing.
09-22-2017, 09:26 AM | #8 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
The needle bearings are decent, but are a greater point of failure than a bronze bushing, no doubt. The issues seem to come from how the needle bearings are contained. When that containment fails, the rocker arm failure follows, not to mention needle bearings in your oil passages/pan.
Don't know that I've heard anyone on this or the Corvette forum complain about a set of bronze bushings.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
09-23-2017, 10:27 AM | #9 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
BTR 100%, that's a company that has been around a very long time and stand behind their work 110%. Always helping racers out.
09-23-2017, 03:21 PM | #10 |
I was thinking going btr I am like every 1 else don't wanna deal with Needle bearing issues
09-23-2017, 05:00 PM | #11 |
129K miles, two cam swaps and original stock rockers.
09-23-2017, 05:28 PM | #12 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
09-23-2017, 07:27 PM | #13 |
Drives: IOM 2SS/RS Join Date: Dec 2011
Smith brothers here, they’re pretty much the same as the straub ones. I don’t feel comfortable with the needle bearing type trunions
09-23-2017, 07:40 PM | #14 |
'It's an experiment'
747 RWHP 794 RWTQ
