![]() Drives: 2010 2LT/RS Join Date: Sep 2017
caliper bleeder valve screw part #?
Hi all,
Is the v6 caliper bleeder valve the same as the V8s? One of mine is rusted and corroded to heck and I need to replace it, and I was thinking of replacing them with speed bleeder valves but I could only find brembo related threads. I think I found the OEM GM Part No.: 88935776 but information seems a bit scarce about aftermarket options. Any input would be greatly appreciated thanks! Edit: Also sorry I just realized this was like engine/powertrain stuff for the LLT, I misread and thought it was just LLT threads period, apologies. Last edited by IlikeMyCamaro; 04-17-2021 at 04:55 PM. Reason: midunderstood the thread category |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Most bleeder valves are one of a couple of different sizes. I went with speed bleeders on mine.
