BORLA
Old 04-15-2016, 09:55 AM   #1
zz430camaro
Drives: 67 camaro, 2015 1LE
160 degree T-STAT
anyone found any benefits in running a 160 deg thermostat? I know on older cars it would help with heat soaking power loss. My 67 camaro runs better with one in it but I dont know if that would be the case with a 2015.
zz430camaro is offline   Reply With Quote
Old 04-15-2016, 11:10 AM   #2
HyperV117
HyperV117's Avatar
Drives: 2010 Camaro 1SS
I've heard that on modern engines changing the thermostat to a lower temperature does more harm than good. The engine never gets to it's real operating temperature and that throws off the built in tolerances that engine was designed with. You might notice some better performance at first with the cooler thermostat but in the long run you will be shortening the engine's life.
HyperV117 is offline   Reply With Quote
Old 04-15-2016, 11:19 AM   #3
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
No need for a 160 ,factory T stat is what you want .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 04-15-2016, 05:27 PM   #4
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Search, brother. You'll find many threads to read on all types of forums about this issue. Modern fuel injected motors run hotter for efficiency, and lowering the thermostat does nothing but change the basement temperature, having no effect on the ceiling temp the motor will always reach when driven hard. The motor needs to warm up quickly to avoid the wear and tear that happens normally before the motor warms up. A lower temp stat will just prolong this warm up unless the car is being operated under severe conditions like racing. If you street drive the car, it is not needed. If you want to make the cooling system more efficient, look into a higher efficiency radiator.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 04-15-2016, 05:49 PM   #5
Unreal
Drives: 2006 Z06
Does your car have enough cooling capacity to run right on the t-stat? Most do not. So it means in the summer it doesnt do much of anything, and in the winter may run too cool. Once the car hits 160, it if full open, and just makes it to it takes longer to warm up, which is when the majority of engine wear occurs. You want the car to get to temp ASAP for best longevity.
There are ZERO advantages, and many disadvantages. So do what you want, but you I suggest not touching it.
Nick
Corvette Z06 -1200ish rwhp
Old 04-15-2016, 06:29 PM   #6
8balldeluxe
Drives: 2010 Camaro SS Victory Red
Last two posts above, agree 200%
Speed Engineering Headers w/ Texas Speed HFC's ~ Flowmaster 2 1/2" cat back w/Flowmaster Super 10's ~ Cold Air Inductions Intake w/ Scoop and WW relocate ~ VMAX CNC Spiral PTB ~ Cross Drilled and Slotted Rotors w/Hawk pads ~ ZL1 Spoiler ~ SCTX4 RDP Tuned
8balldeluxe is offline   Reply With Quote
Old 04-15-2016, 06:59 PM   #7
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
BigBlock69RS is offline   Reply With Quote
Old 04-15-2016, 08:57 PM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I drive year around with a 160 stat a fully modded car. My car runs between 192 and 205 when I drive it. Fans cycle and cool the car down.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 04-15-2016, 10:09 PM   #9
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Mine has the stock tstat with 97k miles. 192-208
Old 04-16-2016, 12:12 AM   #10
zz430camaro
all I know is with my 67 with a 350 run 160 with a 160 and 190 with a 190 and it makes more power on hot days with the 160.
Old 04-16-2016, 01:06 AM   #11
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
Always run them and love them I have only heard of my c-5 at 187000 miles on it so I guess when it dies premature? That car did 548 rwhp and beat on regularly someone will post a things a 14 year said about wearing on a vtec honda earlier.
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
Old 04-16-2016, 10:27 AM   #12
Kendall421
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE
Interesting! I just scheduled my tune. They are going to put a 160 stat in before tuning. They claim it will allow them to put a couple extra degrees of timing into it with 160 stat. Input or opinions?
Kendall421 is offline   Reply With Quote
Old 04-16-2016, 11:18 AM   #13
Unreal
Drives: 2006 Z06
Like prostock john said, 160 stat, car runs at 190+. So a 160, 170, 180, 190 will all be fully open. It will just make it so it takes longer to warm up.
Nick
Old 04-16-2016, 12:46 PM   #14
yenkostyle
yenkostyle's Avatar
Drives: 2015 1LE
This is obviously pointed at me so here is an old corvette book for reference: https://books.google.com/books?id=1T...20myth&f=false
Oh but I'm sure that your going to say this is not a current LS engine reference or it does not have lambo doors or some other excuse why "you'r" right. All I've done is offer a counter point, you'r the one who is now taking this apparent bone you have with me to two threads now....
yenkostyle is offline   Reply With Quote
