05-09-2020, 10:22 AM | #1 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Maxed out another set of injectors. Time for Bosch 210's?
Looking at logs from the stock ls3 and G3X combo, it looks like I will need more Fuel injector with the 427 and G4X blower combo. This will be my third time upgrading injectors, and I want it to be the last.
I've read a lot about the Bosch 210 injectors and it seems guys are using the injector data from ID2000's and having good success. The only problem I've found is people seem to have trouble getting them to idle perfect with regular pump 91/93 octane. However, with E85, they do well. I only run E85, so I won't encounter that problem. 1. Anyone here running them? 2. Are you on the stock ECM? 3. Where did you buy them from? 4. Which data did you use? 5. Does anyone sell them flow matched? EDIT: Currently running FIC1300
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
05-09-2020, 12:46 PM | #2 | |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
05-09-2020, 02:21 PM | #3 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Yes sir. Used one set on my last setup on strictly pump e85. Tons of injector left.
Currently have 2 bosch 210s per cylinder now with alcohol on the same sbe 6.0. I have them both wired to the same driver so they will fire together. I will be starting it up this week and don't suspect ill have any issues
05-09-2020, 10:10 PM | #4 | |
Thanks
05-10-2020, 04:12 AM | #5 | |
And vs racing to avoid knockoffs
05-11-2020, 12:57 PM | #6 |
Drives: 2SS RS ABM A6 Join Date: Jun 2010
First, my car has been down a long time. I start it every so often to cycle oil through it, but that's it.
I think I have the FIC 2100's and e85. I've monkeyed with the idle off & on for a long time, so this is what I recall. The min injector pulse has steps. At one step, the car starts and idles okay, but is actually rich (.85 lambda comes to mind) The next step down the car runs at stoich, but then suddenly goes inexplicably lean. So, if I were to take the time to fix my MAF/MAP values, I think it would idle just fine on that large of an injector. I have the FF sensor, so I suspect it wouldn't make any difference what fuel I'm using. In short, it's ultra-sensitive to tuning. Injectors are usually 3+ms (roughly), but these have to run at .3ms (1/10 of normal) and still seem to handle it. I'm not sure if they'll handle .2ms though.
Jack Bilger
05-11-2020, 03:46 PM | #7 |
Drives: 2014 ZL1 Join Date: Apr 2018
I see 80 percent DC, that's not maxed out...or am I missing something? Edit, nvm!!!!!! lol
05-11-2020, 04:50 PM | #8 | |
05-11-2020, 09:04 PM | #9 |
I am sure it is in this thread somewhere, but did you buy directly from ESS or from JRE
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
05-11-2020, 09:46 PM | #10 |
Are you talking about the ESS kit? If so, I bought from ESS, but Ted handled my last tune. Looking for info on the bosch 210s tho.
05-11-2020, 10:02 PM | #11 |
Sorry. Was thinking this was the original thread about the supercharger.
My Bad.
05-12-2020, 06:01 AM | #12 | |
8.60 @ 157 @ 4200lbs
Yes stock ecu Bought from fuel injector connection Data from hours of time tuning Yes they are matched from fuel injector connection Their is no real data. being our ecu injector stuff is limited
2010 camaro twin turbo 8.60 @ 157 full weight 4200
05-12-2020, 06:44 AM | #13 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Are you planning on tuning with ted again? If so I'd go with what he is used to tuning or at least get his input.
05-12-2020, 11:28 AM | #14 |
