Old 05-04-2011, 05:43 PM   #1
cybergrayls3
Drives: 2010 camaro 2ss/rs..m6..CGM
short throw shifter..more likely to gggggrind?
Hey guys..I was 100% sure I was gonna get a short throw shifter for my car since I'm not thrilled with how the factory shifter feels (even though after almost 3k miles on the car I'm actually getting used to the crappy shifter)...now the reason I've been extremely reluctant about getting a shifter is the whole second gear grind..I know obviously the faster and harder you shift gears the more likely it is yo will grind at some point in time. Now I won't be banging gears all the time, but will just having the short throw in there during normal driving be that much harder on the trans that i will likely start to get the infamous grind? So far knock on wood I haven't had any grinding..my car was built April of 2010..if its way more likely I will get the grind after the install then i will just live with the factory shifter. The shifter I was looking at was the barton..any advice would be great.
cybergrayls3 is offline   Reply With Quote
Old 05-04-2011, 05:52 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
The people who are experiencing grind have the OEM shifter, or the factory hurst shifter. So I feel like you'd be fine.
Click to view my build thread
Old 05-04-2011, 08:43 PM   #3
Synner
Drives: cars
No grinding with my factory hurst and I've been breaking it in less than gently. I thought it was with the aftermarket hurst because the 44% reduction was too fast for the synchros to keep up. Everything in the 20% range has been fine unless they had larger transmission issues going on.
Old 05-04-2011, 09:24 PM   #4
MJOvermann
Drives: 2013 2SS/RS M6 Black
I just installed the Hurst short throw shifter a few weeks ago in my 2LT. Gotta say I love it when driving! But I can say that I do every once in awhile grind a gear (when driving aggressive). This is mostly from first to second gear and rarely when going into third. I need to get use to the shifting pattern being so short. Then this should go away, at least I hope.
2013 2SS/RS, 6M, Black
MJOvermann is offline   Reply With Quote
Old 05-04-2011, 09:26 PM   #5
IROCanSS
Drives: 89 IROC 350
I have zero issues with my aftermarket Hurst. I also swapped out the fluid with Mobil 1. Best thing you can do right there. Mobil 1 ATF.
Old 05-04-2011, 09:30 PM   #6
cleanwhiteSS
2011 White Camaro RS/2SS
cleanwhiteSS's Avatar
Drives: 2011 White Camaro RS/2SS
Never had a grind with my Hurst shifter.
2SS/RS M6, GFX, Borla Atak cat back,Blacked out tail lights, Heritage Grill, 20% tint, 5% on back, Hurst Short Thrower, Black Gills, SLP Shift Skip
cleanwhiteSS is offline   Reply With Quote
Old 05-05-2011, 09:21 AM   #7
2010CamaroRS
Driver of the Blue Demon
2010CamaroRS's Avatar
Drives: '15 Jeep Grand Cherokee Limited
ill know tomorrow when i put mine in
New England Camaro 5
The Few, The Proud, The Hyper Blue Metallics
DT shorties.BBK Intake.FlowMaster AT.Eibach 1'' drop.Hurst Short Throw (44% reduction).Unrestricted Motorsports Gen 1 Style Rear Spoiler.Custom Aqua Blue Metallic Interior Panels.RS Embroidered Head Rests.Interior LED by Oracle.Illuminated Bowtie by Oracle.Footwell LED by Oracle.Grille LED by Oracle.Functional Headliner Console Toggle Switches for LED Lighting.Aqua Blue Engine Cover.RotoFab Radiator Cover.Aqua Blue Fuse Box Cover from RPI Designs.Much More
2010CamaroRS is offline   Reply With Quote
Old 05-05-2011, 10:40 AM   #8
subzero05
Drives: 2010 tbd
aftermarket shifter won;t cause a grind issue typically. that's just an easily used excuse to mask some other inherant problem
subzero05 is offline   Reply With Quote
Old 05-05-2011, 11:39 AM   #9
njdad61
njdad61's Avatar
Drives: 2020 Satin Steel 2SS Coupe
+1
The stock shifter has such a long throw that you could have a problem and never know it. A short throw will increase the symptoms so you notice it more, but it is not the cause.
  • TPW 8/5/19
  • Built 8/2/19
  • Arrived 8/13/19
  • Home 8/16/19
njdad61 is offline   Reply With Quote
Old 05-07-2011, 07:01 AM   #10
cybergrayls3
Cool good to hear..in that case ill be putting a barton in it prettysoon to get rid of this stock crap
Old 05-08-2011, 10:00 PM   #11
cybergrayls3
Could anybody tell me what the reduction rate of the shift is with the barton? somewhere around 20 percent?
Old 05-09-2011, 11:04 PM   #12
DaeGod
Night Fury
DaeGod's Avatar
Drives: 2011 Black 2SS/RS
I grind with my factory hurst on 2nd and 3rd...
DaeGod is offline   Reply With Quote
Old 05-10-2011, 11:00 AM   #13
subzero05
Drives: 2010 tbd
transmission related.. not shifter related
Old 05-10-2011, 11:18 AM   #14
DHSS
DHSS's Avatar
Drives: Empty
I have the LG and the only grind I have had was an immediate power shift on a cold morning and tranny not being warm. Outside of that I love it.
DHSS is offline   Reply With Quote
Barton Short Throw Shifter w/Extras.. $175 shipped Z71456 Transmission / Driveline 2 12-16-2010 07:41 PM
SS short throw shifter onfo detroit iron rules V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 08-02-2010 12:06 AM
Question about Short Throw Shifter FB3 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 17 04-21-2010 11:46 AM
MGW Short Throw Shifter Installed - Pics Camaro21 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 28 03-05-2010 04:30 PM
