#Camaro6
Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro 1LE
Old 02-22-2017, 06:39 PM   #1
Destroyer_1LE
Destroyer_1LE's Avatar
Drives: 2017 Camaro 1LE
GM Factory GEN 6 LT1 6.2L HOT CAM
Take a look at what @ThatGMPartsGuy posted on Instagram GEN 6 LT1 6.2L HOT CAM for $474 and you can keep your warranty if you have it installed by GM.
How much do you think the dealership will charge to do the install?
Destroyer_1LE is offline   Reply With Quote
Old 02-22-2017, 06:55 PM   #2
WhyUMad1LE
Drives: 17 SS 1LE
That would void the warranty unless it comes with a tune.
WhyUMad1LE is offline   Reply With Quote
Old 02-22-2017, 07:00 PM   #3
Destroyer_1LE
Im sure it will be included with the install or the cam. Either way it will be covered under the warranty if they do the install.
Old 02-22-2017, 07:31 PM   #4
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Every bit of research I have done on this points to that it will not be covered under warranty. It won't come with a tune there for no warranty, I really hope I'm wrong though.
IG: @NC_M1SS1LE
FNxR3DNECK is offline   Reply With Quote
Old 02-22-2017, 07:59 PM   #5
glenB
Drives: Chevrolet Camaro SS
GM has no tune for this cam and the cam itself will void the powertrain warranty.
In the last paragraph where it says some parts maintain the OEM warranty, they are talking about things like the GM CAI, valve covers and such.
glenB is offline   Reply With Quote
Old 02-22-2017, 08:16 PM   #6
TJay74
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC
Correct, this will void the engine warranty by installation and tuning of the ECM. GM does not provide a tune for the Hot Cam at all so you would have to get a tune by a 3rd party vendor.
TJay74 is offline   Reply With Quote
Old 02-22-2017, 08:39 PM   #7
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Drives: 2017 Chevrolet Camaro SS 1LE
116.5 LSA isn't choppy enough. Barely will hear it, if I'm doing a cam it will be a 114 LSA or lower.
SS 1LE is offline   Reply With Quote
Old 02-22-2017, 08:44 PM   #8
WhyUMad1LE
Drives: 17 SS 1LE
It's the same as stock actually
Old 02-22-2017, 08:44 PM   #9
IOMike
Drives: 2022 F150, 87 Monte Carlo
With that duration you will hear it. Nothing crazy, but it will sound mean I bet.
IOMike is offline   Reply With Quote
Old 02-22-2017, 10:18 PM   #10
Destroyer_1LE
Well GM is still working on the springs and rockers for the kit, they maybe working on a tune as well.
Old 02-23-2017, 06:52 AM   #11
David@Vengeance
Drives: 2017 Camaro SS 1LE
Definitely will not retain warranty if it states "off-road use only". That being said any GM "hot cam" will see a slight bump in power and maybe a little bit more lope but nothing near what aftermarket camshafts will. My personal opinion it's not worth the time and money to tear down the front of the car/engine to install for that little bit of a bump in power, but that's just me..
David@Vengeance is offline   Reply With Quote
Old 02-23-2017, 07:52 AM   #12
TJay74
GM does not provide a tune for any of their "Hot Cam" options that I have ever seen for the V8 engines. It has always been you buy the cam and then have to use a 3rd party vendor to have it tuned.
If you are thinking you are going to be able to add a GM Hot Cam and be able to stay with in the powertrain warranty it will never happen.
Old 10-14-2018, 10:09 AM   #13
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
Ed Wright did my hot cam tune on my Z28 and later the tune on my 396. I'm not sure if heis still in business or even alive. He was in Tulsa hence me quoting you. I acquired another OBDII AND ECU for the tune. Did same for the Firehawk. Warranty? Who know. Buddy if mine years ago had a 383 LT4 heads LT1 in his 97 Trans-Am. He had warranty work done OK 👌. He had NOS too.
Back then the hot cam was on a 112.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
Old 10-14-2018, 11:46 AM   #14
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Is this mostly for sound? What is the typical HP/TQ increase with a CAM?
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers)
Previous:
18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust)
16' F80 M3 (Ohlin R/T Coilovers)
13' Audi TTRS (APR Stage 1, MSS Springs)
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
TRZ06 is offline   Reply With Quote
