#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Audio, Video, Bluetooth, Nav, Radar, Electronics
BeckyD @ James Martin Chevy
Old 08-06-2017, 11:21 AM   #1
cybercoaster
cybercoaster's Avatar
Drives: 2017 2SS 50th Anv, 1972 RS
Found extra plug after getting car services
Any one if this is an extra plug on the wire harness for other options/car or if it's supposed to go somewhere. The story -
I finally took my 50th Anv in to get the headliner replaced. Really didn't want to but I couldn't take it anymore. When I got home, the garage door opener wouldn't work. I thought, ok, somehow it cleared out. Went to program it and it didn't even light up. Researched and there is a plug for it. Sure enough, they didn't plug it in. My dash cam wouldn't work either and not only did they break my connector (black/red) wires you see, they have the wires pinched in a bolt I guess because I can even pull them out to reconnect. While feeling around for the garage door opener wire, I found this other connector you see hanging. Anyone know what it's for? I can't see a plug for it. Not to mention my dome light plugs were not clicked in. Oh, also when I picked the car up, started it and heard a clunk. Then one that followed every 4sec or so. Turned out they removed my wipers and mounted them back on incorrectly and they were trying to reset to home. How can you not hear that? Anyway - need to know where this plug goes if anywhere. Everything seems to be working from what I can tell.
cybercoaster is offline   Reply With Quote
Old 08-06-2017, 02:09 PM   #2
cybercoaster
And now I notice the lights on my mirror are not working. Checking fuse F50 in trunk for inside rearview mirror, it is good.
Old 08-06-2017, 02:26 PM   #3
talon90
talon90's Avatar
Drives: 2017 Red Hot 2LT RS
If I'm seeing it correctly, that plug should go in to a connector at very back right near the part number label. If it is the plug I'm picturing, you can see it plugged in in my photo attached.
talon90 is offline   Reply With Quote
Old 08-06-2017, 02:31 PM   #4
cybercoaster
Originally Posted by talon90 View Post
If I'm seeing it correctly, that plug should go into a connector at very back right near the part number label. If it is the plug I'm picturing, you can see it plugged in in my photo attached.
Thanks, that is the small plug I had to plug back in for the garage door opener to work. That's how I found the bigger plug all the way to the right in my picture that goes nowhere right now. WHen I was feeling around in the back, I felt it, perhaps it is supposed to go to the mirror somehow since it does not light up.
Old 08-06-2017, 02:45 PM   #5
cybercoaster
Here is a close up of the plug in question
Old 08-06-2017, 05:24 PM   #6
talon90
talon90's Avatar
Hmm. That one I don't recognize. I don't recall seeing that one when I put in your radar detector harness.
Old 08-07-2017, 09:32 AM   #7
cybercoaster
Guess I will take it back to the dealer. I cant find where it goes (if anywhere)
Old 08-08-2017, 08:17 PM   #8
Thompyt
Drives: 16 2SS / 15 Mustang GT
If mirror lights not working, fuse is good, it might plug into the mirror
Thompyt is offline   Reply With Quote
