SDTW Custom Wheels & Tires
Old 05-25-2017, 12:03 AM   #1
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
Post Cam check in thread
Over the past I'd say... 24 months, there have been a pretty large number of cams popping up in this section with overall successful installs.
How are they treating you now? Anyone got anything to report?
I've read where a member said he swapped his springs out every 10,000 miles or so.
So far so good?
Any trouble, close calls, failures, etc?
Dmpsix is offline   Reply With Quote
Old 05-25-2017, 12:36 AM   #2
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Stage III BTR and springs. About 27k miles on it.
Old 05-25-2017, 01:47 PM   #3
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
BTR Stage 4 and .660 BTR springs, installed June 2015. 20k on it and absolutely mint still!
Im thinking about moving to a bigger/better cam later this year.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 05-25-2017, 03:12 PM   #4
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
Lingenfelter GT1-1 (used), Lingenfelter beehive springs.
5K no probems. Well, I had one problem according to some guy in a parking lot. He told my wife as she was walking back to the car to have it looked at cause something is wrong, it shouldn't sound like that haha.
JerTM is offline   Reply With Quote
Old 05-25-2017, 05:43 PM   #5
CFD
Drives: 2SS/RS L99 BLACK
Cam Motion custom grind , a little over 8k, so far everything is good.
CFD is offline   Reply With Quote
Old 05-25-2017, 06:59 PM   #6
WEISHAAR37
WEISHAAR37's Avatar
Drives: 2010 Camaro 1SS
TSP 227/235 and their provided .675 dual spring kit. 3 years and 25k miles no issues. (Knock on wood)
WEISHAAR37 is offline   Reply With Quote
Old 05-26-2017, 02:53 AM   #7
jc615
jc615's Avatar
Drives: Camaro and Sierra
Tsp vvt2 with 15k and then ss4 with 4K. Car is not a daily so doesn't see a ton of miles
jc615 is offline   Reply With Quote
Old 05-26-2017, 06:29 AM   #8
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
Cam Motion 228/236 with TEA dual springs for 8k so far. Motor runs smooth with zero issues to date.
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 05-26-2017, 09:20 AM   #9
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
GPI VVT SS3, I guess I have 10K on it, daily driven, runs 10s.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-26-2017, 09:38 AM   #10
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 NPP BRM
Probably owns a ricer
camguynj is offline   Reply With Quote
Old 05-26-2017, 03:29 PM   #11
pir4te
Moonshiner
pir4te's Avatar
Drives: Holden SS-V L77 flex fuel
EPS custom yet typical VVT 2 spec (mid 20's early 30's) with AFM. So large base circle with moderate lift 0.555" leveraged via rockers. Low stress setup, daily driven 100k on it, runs 11s with a wagon body.
Idles 550 smooth as a baby's bum.
Compression is King.
Naturally as-pirated, all-motor, all alcohol.
pir4te is offline   Reply With Quote
Old 05-26-2017, 07:08 PM   #12
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
BTR Nightfury; 233/242 .629"/.629" 113+3, w/.660 springs.
It's only been three weeks but running strong
504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 05-27-2017, 09:08 AM   #13
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Cammotion stage three nice and mild for now going over 10k, had a tsp 235 239 too sold it with 10k on it prestine from last engine..I break in a cam with br30 not stupidity and some guys thought train that spread a myth because its does not fail immediately like a flat tappet that falls on its face. These springs most likely should be swapped out at 25k on cams , that's to keep them fresh enough to not be worn the F out, some mild cam with beehives..well they are more likely to last longer and not fail on some high rev valve float or worse. Most people are smart enough to go with 8620 cores now as hey ....who knows if they do a break in which racers live on....
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 05-28-2017, 11:53 PM   #14
Camaro Dude
and SLEDGE
Camaro Dude's Avatar
Drives: '13 1LE, 2SS, NPP
Hi lift, and road racing, sounds about right to me as scheduled maintenance, nothing strange there.
sub .60 lift cam, no racing, quality valve spring, no extra maintenance needed, good to go for the long haul.
Like comparing a boosted car at 8 PSI, and one at 15, even if both have the same power plant and turbine. Different maintenance, different game, otherwise, different end game.
Different games at play here.
Camaro Dude is offline   Reply With Quote
