Jason 98 TA
Old 06-01-2017, 06:30 PM   #1
15rs/ss
Drives: 2015 Yellow 2SS LT Z28 cai tune
Swapped SW chambered mufflers for 22 dollar summit mufflers.
I changed out my rear mufflers (sw chambered) because it was toooo loud. I talked to sw for a remedy and they told me $600 to change out the mufflers. I got about 60 bucks in 2 summit 18" mufflers and I really like the way it sounds now.Much deeper and quieter in car.
15rs/ss is offline   Reply With Quote
Old 06-01-2017, 06:31 PM   #2
15rs/ss
https://www.summitracing.com/oh/part...0810/overview/
Old 06-01-2017, 06:52 PM   #3
PostNup
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99
Sound clip??
PERFORMANCE: Cold Air Industries CAI, ADM Race Scoop, CPR Ported TB, Stainless Power 1 7/8" LT, 3" HFCs, Resonator/Muffler Delete, CPR Custom X and straight pipes, Taylor 10.4mm Plug Wires, Circle D 3200 Stall, Nic D ECM/TCM Tune. 365rwhp/363rwtq.
SUSPENSION: Z/28 Rear Outer Control Arm Bushings, Lower Control Arms and Toe Rods. Justice Pete Castor Locks, Front Radius Rod Inserts, Black Magic Sway Bar - Rear, Pegasus Solid Cradle Bushings, JusticePete aggressive street alignment, Firestone Indy 500 tires.
PostNup is offline   Reply With Quote
Old 06-01-2017, 07:02 PM   #4
15rs/ss
no. sorry
Old 06-01-2017, 07:41 PM   #5
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
Good luck fighting off rust
504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 06-01-2017, 08:33 PM   #6
15rs/ss
Thanks
Old 06-02-2017, 12:49 AM   #7
b4wheeler
b4wheeler's Avatar
Drives: 2011 Camaro 2SS Vert
I used Cherry Bombs of the same size and kinda like it, but think it is almost too quiet some times...
I am LS3 exhaust, catless, and cherry bombs..
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Apex Scoop and Bottle, Oracle Ghosted side markers, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, GM Factory GFX kit, lowered 1.0"+, Factory Camaro optional 21" wheels, CDC Roll bar and some powder coating and dipping.
b4wheeler is offline   Reply With Quote
Old 06-02-2017, 05:19 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS L99
That's what I was thinking.
TC should have looked for some stainless mufflers. Probably would not have cost that much more.
If he has the full SW catback, I just don't like the idea of putting mild steel mufflers on to that setup. Swap out the SW for some stainless glasspacks and never worry about it again.
2010 Cyber Gray Metallic Camaro 2SS/RS L99 - Texas Speed Longtubes (Catless), Summit X-Pipe, Flowmaster Outlaw Axle Back (w/MBRP GFX Tips), Vararam OTR CAI, Mike Norris Gen2 Catch Can, Granatelli wires/AC Delco 41-110 Plugs, 160* Stat, Vitesse Throttle Controller, STOP-TECH Slotted/Cross Drilled Rotors w/Hawk HB453Z.585 Performance Ceramic Pads, ZL1 Leather Steering Wheel, ZL1 Add-Ons Wicker Bill Spoiler, SLP Front Splitter - Tune by DynoSteve
Old 06-08-2017, 01:41 AM   #9
SSeniorMoment
Drives: 2010 2SS RS L99 IOM
I have the SW exhaust as well, loud with LTs, need to tone it down a bit now that the SS is cammed.
SSeniorMoment is offline   Reply With Quote
