01-07-2020, 04:15 AM | #1 |
Drives: 2013 1LS Join Date: Apr 2019
How do you jack up the whole car properly?
Made this separate from the other one so I wasn't hijacking it. Anwyay, do you start on the back or the front? The way I did it was pretty sketchy, but I guess it worked. I also bought these jack pads a while back (https://bit.ly/2QVSs1A) and here's how I did it:
1. Jacked the front right on the jack pad (all of them are installed on the pinch welds) and put a jack stand on the side of the subframe. 2. Jacked the other front side the same way and put a jack stand on that side of the subframe. 3. Tried jacking one of the left rear pads and noticed that if I went any higher the car would've rolled off the jack diagonally from me so I did the following: 3a. Supported the front crossmember of the subframe with the floor jack long enough to replace the jack stands with two stacks of four pavers like these (https://thd.co/2QR8qKt) and luckily didn't bend the crossmember. 4. The pavers provided enough support for me to jack each rear side and then I placed a jack stand on each side's subframe flange (the circular part with the bolt in the middle). And then taking the car off the supports was the whole thing in reverse. |
01-07-2020, 06:48 AM | #2 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I have ramps. If i need it really high. Like i have it now. Drive front on ramps with 2x10s in front of the ramps. Block front tires. Lift rear from the diff so the whole rear raises evenly place on jack stands. Jack up front with jack and block of wood to spread the load. Place on jack stands. I also use a piece of carpet on the jack stands to prevent scratching up the underneath. You should have the 4 corners supported with jack stands under the frame. see the other post for front placement of jack stands. The rears I went on the front of the rear subframe. by the mounting bolts.
01-07-2020, 07:19 AM | #3 | |
Drives: 2013 1ss Join Date: Jul 2012
01-07-2020, 07:39 AM | #4 | |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
01-07-2020, 08:24 AM | #5 |
Not sure if this is what you are looking for...
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
01-07-2020, 08:46 AM | #6 |
Banned
Drives: 2012 2SS INFERNO ORANGE Join Date: Apr 2015
i made my own ramps from wood..had them years and they work awesome..only take an hour to make.
01-07-2020, 09:12 AM | #7 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
I do the same. Block of wood and front crossmember gets the front 2 tires up, then put it on stands. Block of wood on the diff pumpkin gets the rear end up and then put it on stands.
I do the front low, and then the rear at the height I want, and then raise the front again if I want it a little higher to work underneath. I also picked up an expensive set of jack stands called ESCO 10499 Low Profile Performance Jack Stand. The round pad is way easier to work with when safely putting the car on stands IMO. I like using the lift points with the round jackstand and not the pinch welds and such.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
01-07-2020, 09:19 AM | #8 |
Drives: 13 IOM 2ss RS manual Join Date: Jun 2018
I use this, which I got at harbor freight. I start by raising the rear of the car and placing jack stands (tires are about 2 inches off the ground) under the points shown in the above post. Then I move to the front and raise it as high as my jack will take it and put jack stands under the frame at the cross member shown in above post. I made some cribbing out of 2 x 4's to go under my jack stands to be able to raise the car to a point that I can have 2 FT. of clearance between the floor and the bottom of my frame rails. I alternate between raising the front and rear until I have the car as high as I need it.
Rectangular Dollars will beat Cubic Inches
01-07-2020, 09:29 AM | #9 | |
01-07-2020, 10:04 AM | #10 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
01-07-2020, 10:12 AM | #11 | |
Drives: 2014 Camaro 1LT Join Date: Aug 2019
I've seen this wood reference several times, but how exactly is it used? I've only ever jacked up my camaro once so far for an oil change, and I used the front cross member with my jack. I didn't have a low-profile jack, so I scuffed the plastic underguard and have no desire to do that again. So, is the wood placed in such a way that it runs from one end of the cross member to the other (perpendicular to the jack in the front)? |
01-07-2020, 10:14 AM | #12 | |
Harbor Freight's low-profile jack gets under and it's a decent price. I recommend it.
01-07-2020, 10:18 AM | #13 | |
Thanks, I may have a look at it. My brother has a low profile, but it would be nice to have one of my own for whenever I need it. |
01-07-2020, 10:40 AM | #14 |
Banned
Thread Tools | |
