#Camaro6
BeckyD @ James Martin Chevy
Old 01-15-2019, 01:42 PM   #1
Torquem
Bannable
Torquem's Avatar
Drives: 2017 Camaro ZL1
Battery / tender pigtail connection
I was hoping you guys could post up pics of how you have your tender pigtails set up. I have an optimate 4 and the eyelets on the pigtail are no where near large enough to work with the underhood posts. I will likely have to cut off the factory connections and solder on some new larger ones for it to work. Just curious to see what other people are doing. Thanks!
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic
Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's
Torquem is offline   Reply With Quote
Old 01-15-2019, 01:56 PM   #2
Mark R
Drives: 2018 ZL-1
https://www.batterysaver.com/store/p61/2120.html
This fits the posts under the hood
Mark R is offline   Reply With Quote
Old 01-15-2019, 02:06 PM   #3
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
You don't have to put them under the battery lugs. Pop the top off the fuse block where the lug connects and there are several M6 terminals you can place the eyelet over and secure with an M6 nut. I think I used #4 location. For the Gnd I attached under one of the mounting screws for the fuse block. Sorry, no pics. Maybe someone else has some.
Old 01-15-2019, 10:45 PM   #4
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
https://www.camaro6.com/forums/showthread.php?t=540177
1hprush is offline   Reply With Quote
Old 01-16-2019, 06:26 AM   #5
Torquem
Bannable
Torquem's Avatar
Awesome. Thanks guys
Old 01-19-2019, 08:47 AM   #6
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Originally Posted by 1hprush View Post
Very nice indeed.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
