03-24-2014, 09:18 AM | #1 |
Drives: 14 v6 camaro 11 yamaha fz6r Join Date: Feb 2014
under drive pulleys
Are they worth the money do they give you a increase in power?
03-24-2014, 09:22 AM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Increase in power, yes. Worth the money, your call. Only 5 or so hp.
03-24-2014, 10:15 AM | #3 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
Its also a PITA to install, you need a special tool, ended up having to get it done at the dealers.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
03-24-2014, 07:03 PM | #4 |
Drives: Ly7 Join Date: Dec 2011
Special claw pulley tool is easy to use. Took me about 20 minutes to do on my vehicle. Tool costs $20.
03-25-2014, 08:42 AM | #5 |
Does it need something other than a pulley puller?
