01-23-2012, 07:56 AM | #1 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
SOLO J Pipes - yep they work
I already had the SOLO high flow cats/mid pipes and MachX catback, which sounded great to me. However, I had the 1800 rpm drone that a lot of people experience. It didn't bother me as much as I think it did my wife, as she has tenitus or ringing in her ears. Long hiway trips were a bit much.
I had the J pipes installed on Saturday, and immediately could tell the difference in town. But once hitting the hiway, the benefits were obvious. The cabin roar was gone, but you could still hear the exhaust rumble. Very nice! Thanks SOLO.
She is only memory now. Last edited by IndeedSS1; 01-23-2012 at 10:59 AM. |
01-23-2012, 10:56 AM | #2 |
Drives: 2017 2SS Hyper Blue Join Date: Apr 2009
Do you mean,you ordered the j pipes and had them welded on?
Mods-Corsa Extreme Axleback
01-23-2012, 11:01 AM | #3 |
Correct. Ordered just the add-on J pipes portion and had them welded on.
She is only memory now. |
01-23-2012, 11:26 AM | #4 | |
Drives: 16' 2SS M6 Join Date: Feb 2010
Did you have to adjust the j pipes once installed from the preset position? If so, how did you do it? I am going to be installing the high flows soon, and concerned about any drone from that. Thanks! |
01-23-2012, 11:41 AM | #5 |
Good deal.This is something I am thinking of doing.The low rpm drone on my borla s-type catback is driving me nuts.Just a matter of getting prices onthe j pipes from Solo and the price of having someone install them.Did you find a drastic change in the sound of your exhaust itself after the install that you would consider a minus?
01-23-2012, 11:47 AM | #6 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
They sure do work and the Solo exhaust sounds great as well !!
01-23-2012, 11:57 AM | #7 | |
Drives: '14 Black 2SS RS Join Date: Jul 2011
I had some made up for my MRT. |
01-23-2012, 12:07 PM | #8 |
There was a slight different in sound. Maybe slightly quiter but I only noticed it because the shop that did the install, revved the car before and after and I could hear it in the waiting room. It still sounds great to me.
I didn't change SOLO's preset length on the pipes. As far as I can tell it's killing most of the done normally found from about 1600 to 2000 rpm. or 65-80 mph in 6th gear, right where they had it set.
01-23-2012, 12:13 PM | #9 |
Thanx forthe info!
01-23-2012, 03:06 PM | #10 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Glad it worked out for you Lee. They do look interesting and it's nice that they tuck up under everything.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
01-23-2012, 05:51 PM | #11 | |
The difference without drone is huge. If I drop a gear and run the rpms up above 2100, I can hear the drone come back in. If I ever get 4.11 gears I'd have to adjust the Js.
01-23-2012, 06:38 PM | #12 |
Drives: 2011 Camaro 2ssRS Ls3 Join Date: Aug 2010
I added j pipes as well. Best mod yet lol. Other than the cam
01-23-2012, 06:48 PM | #13 | |
5th Gen
Drives: 10 SS Join Date: Jul 2010
P.S. IndeedSS1 did you just call up Solo-Performance and ask for some J-Pipes? Last edited by 4thGen427CI; 01-23-2012 at 07:45 PM. |
01-23-2012, 06:50 PM | #14 | |
Drives: Drives a 2012 IOM 2SS/RS 6M Join Date: Nov 2008
CAMARO 2SS/RS 6M
Similar Threads | ||||
Solo Performance Mach X-LLT J-Pipe Cat-Back Exhaust | GOINGSOLO2 | V8 Bolt-Ons & Tunes | 180 | 05-27-2014 03:01 PM |
SOLO Performance Camaro CONVERTIBLE Cat-Back Exhaust Kit | GOINGSOLO2 | V8 Bolt-Ons & Tunes | 18 | 12-20-2011 06:17 PM |
Solo Performance Mach XL exhaust with J-pipe and High Flo Cats installed! | Yellow Camaro | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 8 | 08-30-2011 10:18 PM |
Solo "J" Pipes | VictorySS | Local Marketplace | 1 | 08-05-2011 01:40 PM |
My Solo Mach X to Corsa Review Read On! | 55Designs | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 25 | 07-11-2010 09:35 AM |
