10-19-2015, 02:13 PM | #1 |
Drives: 2015 2SS/RS vert, Spring Green Edtn Join Date: Jun 2014
Weird spots on my headlights
I have what looks like tiny chips on my headlights. They don't show when the lights are off, but when I turn them on at night I get the tiny glowing dots you see in the pic. I can't feel them with my fingers, but they could be super tiny and made to look larger from the light. Any ideas, and how to clean it up?
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015) |
10-19-2015, 05:55 PM | #2 |
Drives: The shiny ones. Join Date: Mar 2010
Did you try claying? Could they be bugs?
http://adamspolishes.com/video?video_id=21 |
10-19-2015, 09:13 PM | #3 | |
10-19-2015, 11:37 PM | #4 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Could be some type of debri on the inside of the lense.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
10-20-2015, 03:43 AM | #5 |
It sounds like this isn't one of those things that's common. I'll take a look at it through a magnifying glass tomorrow. The car is a 2014, so hopefully it's something that will be covered under the warranty.
10-20-2015, 08:04 AM | #6 |
Drives: 2015 2LT Join Date: Aug 2014
My 2015 has the same exact same issue. Outer surface is smooth as can be and clean! Seems like it must be on the inside.
10-20-2015, 08:10 AM | #7 |
having FUN now 13.66@101
I have the same issue on my 2010. I always felt it was wear and tear from rocks, and sand. I see the same thing thru my windshield. Looks like it has been thru a sand storm.
I have come to accept it as is.
10-24-2015, 10:22 PM | #8 |
Drives: 2013 Camaro ZL1, 2006 Chevy Equinox Join Date: Apr 2013
Same thing on my 2010. I beleive it is in part due to corrosion of the plastic.
10-25-2015, 07:11 AM | #9 |
Yep, same thing here (2010).
MYBADSS
