Old 04-29-2016, 07:59 PM   #1
drago
Drives: 2015 1le
added e force
went with the 3 year 36000 mile warrenty so i am stuck with the tune from them. car has axel backs plus cradle bushings and trailing arms. so basicly stock. put 475 rwhp 612 at crank
drago is offline   Reply With Quote
Old 04-29-2016, 08:47 PM   #2
Must go faster
Drives: 2011 2SS
You'll love it!
I've had great luck with the Eforce. I'm at 650 whp now and no issues what so ever!
Must go faster is offline   Reply With Quote
Old 04-29-2016, 08:52 PM   #3
cc-rider
Drives: 2010 Camaro SS
Congrats. You're going to love it.
My advice...forget the warranty and keep going. These engines have proven themselves to so incredibly robust. With a proper tune (available from many) there is no reason why you shouldn't consider dumping the warranty and maximizing what you have.
cc-rider is offline   Reply With Quote
Old 04-30-2016, 08:06 AM   #4
BradySS
Drives: 2010 Camaro 2SS
Best case scenario it'd be 546HP at the crank not quite 612HP. That's with a 15% drive train loss. Sweet setup. How's it feel with the blower?
BradySS is offline   Reply With Quote
Old 04-30-2016, 08:46 AM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Not to rain on your parade, but a cam'd camaro with full bolt on's can make that power without the blower. Go get yourself a proper tune, there is a lot more power to be had there. Personally I wouldn't worry about the power train warranty. Dont get me wrong, horsepower will always find the weakest link, but IMO you've got a log way to go before you start risking internal failures.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 04-30-2016, 12:58 PM   #6
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Where in Tn. do you live?
MODS:
Old 04-30-2016, 07:02 PM   #7
UNRIVALED SS
UNRIVALED SS's Avatar
Send a message via Yahoo to UNRIVALED SS
Awesome !
You have a good strong car that will do a burnout on command and be really fun to drive. Not to address the negative but, you are a $300 cam and headers away from huge power. So, don`t worry about the wet shirt trying to be critical.
Great choice, have fun. Drive the car, buy more tires. You`ll needem
UNRIVALED SS is offline   Reply With Quote
Old 04-30-2016, 07:02 PM   #8
SilverIceman
SilverIceman's Avatar
Drives: Camaro SS SIM
Nice!
I did the same, paid for the three year, but only managed one year before giving in and re-tuning. Do what you need to, but you won't regret going up! Research and get all the fuel upgrades recommended when you decide to go bigger.
Enjoy all that new torque!
MYBADSS
SilverIceman is offline   Reply With Quote
Old 04-30-2016, 08:28 PM   #9
drago
Drives: 2015 1le
sevierville tn. as far as the crank hp. the dyno that rdp uses shows crank hp (i don't know how) i know their is more hp their (wife is on me about keeping the warranty lol) i love the blower, it is very streetable
Old 05-01-2016, 11:05 AM   #10
10aSSee D
10aSSee D's Avatar
You are not to far from me, I live in Lenoir City.
MODS:
Old 05-01-2016, 01:43 PM   #11
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
Good choose. I have the E-Force also. I installed it myself, so I didn't get the warranty. I had LT headers before the S/C, so I needed an tune because it was running lean. During the tune, found out it was running out of fuel. I then added the Janettey fuel rail upgrade kit, ZL1 fuel pump and 72# injectors. It runs great now 546/rwhp and 522/wrtq. Which is 642 crank HP. And get's 24 mpg on a trip. By the way I now have 36K miles on the E-Force.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 05-01-2016, 05:05 PM   #12
drago
Drives: 2015 1le
mine is a 1le so i hae the fuel pump, of course the rails and injectors are edelbrock, i think #58 injectors
Old 05-02-2016, 12:13 PM   #13
sscamaro
sscamaro's Avatar
The fuel line attaches to the rear of the passenger side fuel rail on the G-Force S/C, then a line runs in front of the engine to the front of the drivers side fuel rail. That means the fuel has to travel in the passenger side fuel rail across the front of the engine and then into the front of the drivers side of the fuel rail. With the Jannetty fuel rail upgrade kit, the fuel enters the rear of both fuel rails. As I said I was running out of fuel, when I added the ZL1 fuel pump, I didn't want to take the chance that the injectors weren't big enough, so as recommended by my tuner I installed the 72# injectors. Stock E-Force injectors are 52#.
Old 05-06-2016, 06:49 AM   #14
NHCamaroSS
NHCamaroSS's Avatar
Awesome congrats! I did the same kit as well two months ago and it turned the car into a true beast. Blows people's minds away the difference in pull when taking them for rides. I skipped the warranty as well and had a custom tune done due to already having a cold air intake and not using their air box cover. Picked up an extra 20hp that way too.
2010 Camaro SS Inferno Orange 6-Speed . Edelbrock E Force Supercharger, Volant Cold Air Intake, Magnaflow Exhaust, River City Creations Emblems, Oracle ghosted LED markers, SLP faded gills, ...531 rwhp, 490 rwtq
NHCamaroSS is offline   Reply With Quote
