Old 06-20-2018, 05:37 PM   #1
Grey2ss
Grey2ss's Avatar
Drives: 2015 Camaro 2ss
Auto Center Console help
I can't seem to find a good link to removing center console for 2015 SS automatic shift plate. Can someone provide a link. Latte spilled and shifter is sticky and need to pull it up and clean it.
I want to make sure I pop it off correctly and not break any tabs.
Grey2ss is offline   Reply With Quote
Old 06-21-2018, 06:45 AM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '19 Corvette Stingray
are you wanting to only remove the shift plate, or the entire console?
I know of a thread that has instruction to remove the whole console, but all the pictures are missing because of the photobucket snafu.....but the text of the instructions is there. maybe that will get you want you need.
https://www.camaro5.com/forums/showt...highlight=PDIM
Old 06-21-2018, 10:36 AM   #3
Mike14bumblebee
Mike14bumblebee's Avatar
Drives: 2014 yellow 2SS/RS
It comes off pretty easy. Pry up on one edge and the u can see where the clips r. I had no problem with tabs breaking. Once you get the trim around the shifter off, you will see the bolts to get the actual shifter assembly out
K&N, Borla ATAK axle back, resonator delete, Vitesse, Zl1 wheels, ACS rocker panels, 1LE splitter
Mike14bumblebee is online now   Reply With Quote
Old 06-21-2018, 11:10 AM   #4
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2014 Camaro 1SS RS SIM
Start pulling up from the farthest back edge and slowly pry up, all the clips come up pretty easily and then you can unclip the electrical connector towards the back.
2014 SS - L99 1SS/RS - "AleSSandra"
SSEssence is offline   Reply With Quote
Old 06-21-2018, 11:32 AM   #5
Tech@HurstPerformance
Tech@HurstPerformance's Avatar
Drives: 2016 Camaro SS
Take a look at the link below. These are the installation instructions for the Hurst Billet Plus Manual Short Shifter. However, the center console removal should be nearly identical. Hopefully, this helps you out, good luck.
-Jason @ Hurst
Phone:(707)544-4761 M-F 7:30am-5pm PST, Sat./Sun. Closed
Website:www.hurst-shifters.com Facebook:Hurst Performance
Instagram:@hurst_performance YouTube:Hurst Performance
Twitter:@HurstShifterUSA
Tech@HurstPerformance is offline   Reply With Quote
Old 06-21-2018, 09:27 PM   #6
Grey2ss
Grey2ss's Avatar
Perfect thanks removed, cleaned and no broken clips.
