10-05-2013, 01:46 AM | #1 |
Drives: 2010 Camaro 2SS/RS LS3 IOM Join Date: Aug 2012
Additional Recommended service worth it?
So I had my car in for an oil change and they tried to up-sell me on a bunch of stuff. My car is a 2010 with 58,000km. They asked if I wanted:
So is any of the above worth the extra cost? Is a Mobil1 oil filter that much better than a standard one? Should I get the differential flushed? I use nothing but petrocan Ultra94 fuel or premium if I can't find ultra94, so do I really need to get the fuel injectors cleaned? He really tried to sell me on this one, saying the performance difference would be really noticeable. Comments please
10-05-2013, 07:40 AM | #2 |
Filter, the stock filter should be fine.
Diff fluid changed is a good idea, I did mine around 20,000. Injector cleaner can be bought and poured in yourself. Fuel system flush?? Not sure about that one? Probably not needed.
10-05-2013, 09:51 AM | #3 |
Drives: Camaro ZL1 Join Date: Aug 2009
Services
Servicing your diff is a good idea, use proper fluids, the rest IMHO is a waste of money
Steve |
10-05-2013, 09:56 AM | #4 |
"The Wife"
Drives: 2013 2SS 1LE Join Date: Jun 2011
I would do the diff service, but the rest is not needed.
10-05-2013, 12:57 PM | #5 |
I sell Camaro's
Drives: traded 11 2SS RS SGM for 13 SS 1LE Join Date: Mar 2009
I'd service the diff service personally, but anything other than what GM recommends in your owners manual is simply the dealership trying to make money. Also Switching to the mobil1 oil filter can cost you if anything goes wrong with it as it not an OEM filter
follow the link or pull out your owners manual for your maintenance schedule http://www.gm.ca/gm/english/owner_ce...evrolet_camaro |
10-05-2013, 01:07 PM | #6 |
Drives: 2016 Mazda6, 2011 Mustang 5.0 Join Date: Mar 2010
Follow the owners manual, and you generally can't go wrong.
The diff service may not be a bad idea, particularly with a limited slip. Fuel injector cleaning nowadays, with all the additives in the gas, is probably not necessary. I wouldn't do it as long as its running right. My Alero has 173k miles (that's 278k Canadian), and I've never had it done and the engine is still as smooth and efficient as when it was new.
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive." . 2022 1SS 1LE (Coming Soon) |
10-05-2013, 01:51 PM | #7 |
Assuming the rear axle mentioned in the manual is the same thing as differential servicing, the manual says I don't need it until 160,000km! Where would they get the idea it is required now? Btw, this was not done at a dealership, but at a lube city express oil change (I had a $22 off coupon )
10-05-2013, 02:06 PM | #8 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Our van at work just had the dealer injector flush done and it runs a lot better.
Get the flush done before the oil change if your doing it.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
10-05-2013, 04:49 PM | #9 | |
I sell Camaro's
Make sure you are sticking with OEM filters when you go to those places! Had a filter disintegrate in an engine that was not a OEM filter.Engine needed to be replaced and was not covered under warranty. |
10-05-2013, 05:40 PM | #10 | |
I opted for the standard filter, but I had never heard of this mobil1 premium filter before.
10-07-2013, 09:12 AM | #11 | |
XLR8TNG
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
10-07-2013, 02:45 PM | #12 | |
I sell Camaro's
10-07-2013, 04:04 PM | #13 |
MikeNoMaro
Drives: A 2016 Challenger R/T M6 STP Join Date: Sep 2009
1) I've looked at 5 brands of filters compatible for the LS3 camaro, once you compared how they are made, you can tell quickly which one has a better craftsmanship... Mobil 1 is on the top end of that Spectrum. It’s what I used since day 1. And I have 34k miles on the odo and 5 filter/oil changes. Mobil 1 all the way.
2) Differential fluid flush: once every year (Amsoil 75W-90 Limited Slip with slip additive)
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016. |
10-08-2013, 08:03 AM | #14 |
XLR8TNG
Unfortunately you are correct! There are a ton of low quality lube facilities out there. I was more focusing on the products they carry. All people have to do is ask to see the warranty approval on the filters being installed. If the lube facility won't or can't then I recommend people carry on and find a place like mine that is happy to ease your mind! I hope you don't feel I was being crude towards you Layla. That was not my intent. I have taken my truck through other lube shops just to see how the competitors roll and in some cases I just couldn't believe how terrible the service and workmanship was. The un needed up sales were the biggest issues I had. Hence the reason that my staff is NOT on commission. (You can tell right away the shops that are). Sure our sales average may not compare to other shops but our customer return rate is unmatched I'm sure. I prefer the customer loyalty over the quick buck any day! Just like you selling vehicles. Long term relationships are keys to success!
