08-04-2022, 09:58 AM | #1 |
Connect a line from taillights to 3rd brake light?
My 3rd brake light stopped working and after searching apparently I have to disassemble the back of the car till I get to the cables, I did get a z28 spoiler with a wickerbill so I'm thinking there's no need to fix the oem since it won't be visible to the other drivers anyway, instead I'm thinking of buying an aftermarket 3rd brake light and use it on the spoiler, is it possible to connect it to the taillights cables instead of the the whole disassemble hustle in the back of the car?
08-04-2022, 10:29 AM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
On some GM vehicles, your cruise control won't work without the factory 3rd brake light. I don't know if this is true for the Camaro.
You should be able to run a 3rd brake off of the existing brake lights, but it might throw a trouble code if the change in resistance makes the BCM think a bulb is out. |
08-04-2022, 11:48 AM | #3 |
Drives: 2013 L99 Join Date: Jan 2019
I did this when my 3rd brake light went out. I used the OEM 3rd brake light wire, I just cut it and spliced it then ran the wire with the rest of the wires up into the trunk hatch to the aftermarket spoiler/brake light
08-04-2022, 01:03 PM | #4 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
08-04-2022, 07:45 PM | #5 | |
