03-25-2021, 11:44 AM | #1 |
Drives: 2014 2SS-RS NPP Exhaust Join Date: Feb 2015
1LE suspension components for sale
I have a few 1LE suspension components for sale.
These struts and shocks were installed on my 5th gen and I ran them for about 9k miles before I purchased Z28 components. These components were installed on my car in March 2016, and removed in September 2016 when I upgraded to Z28 components. I have both front struts and both rear shocks for sale. I also have a few sway bars (oem) 22795025, 22786260 (OEM 1LE rear sway), 22875934 as well. Cosmetically they have a few scratches from install, but they worked well when in the car. I have included pictures, I'm in southern California looking for $300 for all 4 struts/shocks, and $75 for the 1LE rear sway. |
03-25-2021, 01:24 PM | #2 |
Drives: 2014 2SS/RS/1LE Join Date: Aug 2016
Were the struts/shocks new when they were installed?
03-25-2021, 02:02 PM | #3 |
03-25-2021, 02:45 PM | #4 |
Are you willing to ship? If so, how much to ship to 74115?
03-26-2021, 05:41 AM | #5 |
Drives: SS Join Date: Jun 2016
03-26-2021, 05:36 PM | #6 |
03-27-2021, 04:28 AM | #7 | |
Banned
Drives: 2010 LS Join Date: Feb 2021
front sway-bar and end links, you only need to drill the holes bigger for the larger threaded struts on the end links. The nuts are bigger too. I updated my '10 with the 1LE front sway-bar and end links, and I simply drilled the hole in the perch for the link, to 15/32" If you use the 1LE front struts without the 1LE sway-bar stuff, then the hole will be too big for the the non 1LE end-link stud. Rear 1LE sway-bar: 10-11, not sure on 12, need the updated rear LCA, that has the mount hole for the ROD type end link. You also need brembo rear calipers for the bar and links to clear. The new LCA part has both the dog-bone end-link perch, and the hole for the ROD end-link. I have a ~5 mile take off 1LE rear sway bar kit I can't use. I am not going to change the caliper. I did change the rear LCAs, was replacing them anyway. I also have ~5 mile 1LE front struts, but I will be using those eventually. 1LE Rear struts, you need nothing, I also have those on my '10. |
04-10-2021, 12:37 PM | #8 |
Bump
