Old 07-01-2015, 07:06 PM   #1
calflan
calflan's Avatar
Drives: 1LT; IBM; 6 Spd Manual
2010 LT Brake wear
Curious what kind of mileage is typical before brake pad changeout on a 2010 LT?
If you've done yours, when did you do them, how worn were they and did you do all 4 at teh same time?
Thanks
1LT; Airaid CAI; Flowmaster American Thunder Axelback; Int Floor Lts; RS Spoiler; Radio Controls; Sequential tail lights; Oil Catch Can; VMAX Throttle Body; MACE plenum spacer; Mace manifold insulator[/I]
calflan is offline   Reply With Quote
Old 07-02-2015, 10:19 PM   #2
GavinF
1BlueLT
GavinF's Avatar
Drives: 2007 Z06
bump
GavinF is offline   Reply With Quote
Old 07-04-2015, 08:52 PM   #3
calflan
calflan's Avatar
All these views and no one know seems to know when they have had to change their brakes, really??
Old 07-04-2015, 09:14 PM   #4
mulehead7
stubborn as a ...
mulehead7's Avatar
Drives: '94 Trans Am
I've been getting some brake squeal for about 6 months and I've just ordered new pads. I've got a '10 LT with 60,000 miles. Picking up Wagner Thermoquiet pads for all four wheels on Tuesday. The stopping power hasn't seemed to decrease but the squeal is getting worse everyday.
mulehead7 is offline   Reply With Quote
Old 07-04-2015, 11:32 PM   #5
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
before i changed my brakes to the zl1 conversion, I pulled mine off at 20k and i would guess they had 20-30k more.
Lil' Nasty is offline   Reply With Quote
Old 07-06-2015, 05:47 PM   #6
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
I upgraded my brakes at 75k and still had pleanty of meat left on them.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 07-15-2015, 07:48 PM   #7
mulehead7
stubborn as a ...
mulehead7's Avatar
Changed those brake pads out last Saturday. I could have gone another 50k. But it was an easy change. A floor jack and a 14 mm socket for the caliper and a socket for the lugs. Less than 90 minutes and it was a done deal. No more squeal. Now I can slip through the neighborhood at 5 am with relative ease.
Old 07-18-2015, 09:52 PM   #8
MoCamaro10
Drives: 2010 Inferno Orange Camaro
Just swapped my fronts out when I changed my rotors @ 45K. The pads were a little over half way down.
MoCamaro10 is offline   Reply With Quote
Old 07-19-2015, 06:44 AM   #9
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
I installed the following at 60K miles:
R1 Rotors (Premium) front and rear
Hawks Ceramic pads (yellow) front and rear
Motul RBF 600 DOT 4 Brake Fluid 100% synthetic
Goodridge Stainless Steel Brake Lines
The brakes I took off looked almost new. I travel mostly highway back and forth to work, 70 miles round trip daily.
I went with the change because I wanted to upgrade the brake system as it was on my list of mods to do and it was time.
Old 07-22-2015, 09:41 PM   #10
mulehead7
stubborn as a ...
mulehead7's Avatar
Nice job! I put those same R1 rotors (not as big) on my '94 a couple years ago and Hawk pads too. I couldn't believe how much better it was.
I wish I would have changed the brake lines on my '10 change out but I'll have to claim laziness. They look really good in the pic.
I will say after a couple weeks the ThermoQuiets are about 10% better than stock.
It's fun to go fast but there is a lot to be said about stopping...
