Old 03-09-2018, 07:50 AM   #1
13SSCamaro
13SSCamaro's Avatar
Drives: 2013 Camaro SS
What nitrous kit do you recommend, and any issues using it on a Rod mod GPI intake?
As the title asks: What nitrous kit do you recommend, and any issues using it on a Rod modded and ported GPI intake? I have read the nitrous thread and done some reading through various threads and still am not sure. Who here has experience with nitrous on their LS3 camaro and can help guide me in the right direction. Current mods are in my sig. I am upgrading to E-85 with the flex sensor and bigger injectors so anytime i run the nitrous it will be on E-85. Looking to do a 150 shot max. I am also looking to do the rod mod and intake porting by GPI before I install the nitrous and bigger injectors. Is there any issue running that intake with nitrous?
Thanks in advance for any help, I just want to make the right decision the first time as I am new to Nitrous. And yes the car will be tuned by a well trusted shop.
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, ID850 injectors,ZL1 fuel pump, Flex sensor and E-85, Mantic 9000 and 1LE 3.91 diff 512rwhp/462rwtq
13SSCamaro is offline   Reply With Quote
Old 03-09-2018, 08:40 AM   #2
WoodBoss
"Old School"
Drives: 2010 2SS L99
I have installed the ZEX Kit and have had very good luck with it with a 125 shot. I have the stock intake (No Rod Mod). I would consult the guys at GPI about usage with their intake manifold or hit up Dynosteve on here about the Nitrous kit. He has a good deal on the ZEX kit and is very knowledgeable regarding the mods and applications for using it. Link to the video of my install if you have not already seen it.
WoodBoss is offline   Reply With Quote
Old 03-09-2018, 09:35 AM   #3
13SSCamaro
13SSCamaro's Avatar
Thanks. I subscribed to your YouTube channel and will watch some of your vids in a bit. I figured I would email GPI if I don't get a good response in here. Are you running a basic nitrous kit? Or is it a 90mm plate kit and did you add anything like a timing retard box or any other accessory?
Old 03-09-2018, 12:08 PM   #4
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Definitely reach out to GPI and ask. Theoretically, I don't see why nitrous would be a problem with a rod mod, other than it may be a little weaker than a stock manifold with regard to resisting damage in the event of a backfire. But I don't think a stocker would survive much better. But flow wise I can't see a reason it wouldn't pull a wet shot through just as well or better than the stocker.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 03-09-2018, 04:07 PM   #5
13SSCamaro
13SSCamaro's Avatar
That was my thought as to how weak it would make it, but true, these manifolds are weak as they are. I will see what they say
Old 03-09-2018, 07:20 PM   #6
13SSCamaro
13SSCamaro's Avatar
I see the NOS kit comes with the progressive controller all for under $800. What else would i really need? a timing retarder, purge, anything else?
Old 03-10-2018, 03:46 AM   #7
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
So far I've had no issues using the Nitrous Outlet plate system designed for our car. Their customer service is excellent. You will definitely need more fuel if your tapping off the rail and using E85. Possibly a dedicated fuel system for the N2O. Depends on the capability of what fuel pump you install in the tank. I would add a wideband as well.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 03-10-2018, 06:25 AM   #8
13SSCamaro
13SSCamaro's Avatar
Good info, thanks. I do have a wideband to install which is a good piece of mind. As far as the fuel pump, what did you do? Will a ZL1 fuel pump be enough or did you go with a stand alone?
Old 03-11-2018, 02:39 PM   #9
gsxrturbo
Drives: 2010 ss
My friend has a 05 corvette Ls2,with full bolt ons,he has a zex kit and running 175 shot,WITH A TUNE.No problems yet.
gsxrturbo is offline   Reply With Quote
Old 03-13-2018, 03:02 PM   #10
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Installed a Nitrous Outlet dedicated pump for the N2O about a month ago. Roads and weather is still bad.
