09-05-2019, 04:06 PM | #1 |
Drag wheel & tire advice/suggestions please!
Hi everyone. I checked out the general wheel/tire info before posting this, and it was excellent. However, I am completely paranoid.
I need help with tire and wheel sizes for my 2012 SS M6 (1.5" lower springs) for Street Car Takeover ATL (12.00 index class). Thoughts on: 17 x 4.5" Race star front (92-745242G) 17 x 10.5" Race star rear (92-705253G) M&H Racemaster Front Runner 28 x 4.50-17 M/T ET Street R Bias-Ply Tires 28 x 11.50-17 The advice I've gotten here so far has been EXCELLENT so I thought I'd ask. Any advice would be appreciated!!! |
09-07-2019, 09:16 PM | #2 | |
Drives: 2014 2ss/rs Join Date: May 2012
09-07-2019, 09:20 PM | #3 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
I might be concerned with clearance on your LCAs being lowered.
09-09-2019, 01:30 PM | #4 |
Thank you both for the heads up. I managed to get all 4 of the wheels for $780 shipping included. As long as I don't mount tires, I can return them for a full refund if they don't fit. Measurements say they will be ok, but you know how that goes.
I will definitely update when I test fit the wheels and then when the tires are on. If nothing else, it should be entertaining. Fingers crossed... |
09-09-2019, 01:42 PM | #5 |
You won't know if there are clearance issues until the tires are mounted and car is on the ground. Good luck. BMR adjustable LSAs may be in your future.
09-09-2019, 02:27 PM | #6 |
Drives: 11 camaro Join Date: Mar 2017
I run that set up in 10 sec index, hooks everytime. Can't go wrong IMO
2011 1SS/ Thompson mtrsprts 416,Katech rotate assembly and cnc ls3 heads. Ferrera st. valves,BTR 685 Spr. F1A Procharger,3.70 pulley on 12 rib.Holley aux fuel pump,ZL1 fp and fpcm,dual alky control,Vmax TB,DSX E-85 sensor, fic1300 inj.Lsxperts custom cam,melling OP,mishimoto dual pass HX, ARH 2" headers, MD 4l80e, FTI 3200 stall,3:73 zl1 cradle, BC coil overs ,pfadt sway bars, EBC brakes and slotted rotors: 843rwhp tuned by LSXPERTS
09-10-2019, 02:17 PM | #7 | |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
This.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
09-11-2019, 11:41 AM | #8 |
Thank you for the comments.
Update: Of course the front wheels fit fine. The rear wheels are tight when it comes to the ridges/bumps on the edge of the caliper. I see a little grinder action in my future... I almost made a mistake by considering Hoosier slicks for the back. Not DOT approved, so I'd have run into an issue at Street Car Takeover. Going to order them today from Summit unless someone has another suggested source. I hope to have them mounted and check the fit over the weekend. Maybe... |
10-02-2019, 10:50 AM | #9 |
Drives: 2013 Black camaro ss Join Date: Jan 2017
Any one with skinny race stars up front have any vibration issues? my whole dash shakes 50-60+. At 100 mph feels like the wheels are going to fly off. I had them rebalanced at 4 different shops at least twice. Ive replaced rotors and pads just as a guess... I have heard from one other person having the issue and it was the race stars... want to see if anyone else has this issue before i buy a completely new set of wheels.
Thread Tools | |
