10-04-2016, 02:44 AM | #1 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
10hrs working on the Car... Wash/Wax and JRE Install
The first 6 was wash, clay bar, Chemical Guys All in One V4, Jet Seal, and Meguiar's Ultimate Wax...
Here is a pic before the jet seal and wax I was planning on using Chem Guys 50/50 but it had a weird consistancy to it, not like the first time i used it about 8mo ago maybe... Might have went bad, so i went to Orileys picked up the Meguiar's. Last 4hr were installing the 23% lower, idle bracket, and ID850s ... And clean up. Got the parts for Ten Jannetty ... And tune for the car, fired right up Couple things with the injector install, i used a grinder to access the front bolt, got it close to the bolt head then punched off the remaining lip with a hammer and flat head scree driver... Touched it up with a sharpie. I took the s/c coolant lines off and moved everything i could out if the way... Minimal s/c leaking... Running a rotofab resv ... I just took the injector fuel rail out if the car. It made it super easy to swap... Kind of a PIA to get them in and out... Missing the Gen 4 fuel rails The idler bracket was simple enough except it called for 37ftlb tq on the bracket to the pump, whatever reason the stock bolts would never tq to that... Was like the alum bracket was being compressed ... It would click at 25lb on the tq wrench anything over would just spin it ... Blue loctited so should be fine... Had to zip tie the transcooler lines down to the sway bar keep it from rubbing on the pulley. Tomorrow i will put in the BAP and Wideband... Be all set to go. Cam should show up this week or next week! |
10-04-2016, 07:53 AM | #2 |
Drives: Fast Join Date: Mar 2015
Nice! Post videos after the cam install please!
10-04-2016, 09:05 AM | #3 |
Ted.
www.jannettyracing.com
10-04-2016, 05:15 PM | #4 |
Drives: 2015 Camaro ZL1 Join Date: Mar 2015
Damn, you have more energy than I do for sure. I'd be wiped out after either one of those jobs. Lol!
2015 ZL1 #377
10-04-2016, 05:58 PM | #5 |
Drives: 2013 ZL1 Triple Black Vert M6 #5591 Join Date: May 2013
Car looks great and Jannetty is the man.
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice.. |
