04-21-2015, 01:37 PM | #1 |
redleader
Check Turn Signal LEFT ... & RIGHT ?!
copying this Post over from my UK Forum post FYI:
http://www.camaro5.com/forums/showthread.php?t=405055 I'm getting a dash warning for both Rear Turn Signals :-( Front Indicators & Bulbs are OK, Side Indicators [UK IVA*req. MOD] LEDs are OK, Rear Indicators LEDs, or temporary Glass Clear Bulbs ones are not lighting up. I swapped out/over the LED bulks, same issue. I have bench tested the LEDs and Bulbs and they work OK. Here's some photo's, is that Purple wire that appears to be cut an issue?! After Note: no the purple is an IVA* MOD in the UK and was there all along from 2009/2010 when it was imported and all was working fine with that cut before for the past 5 years. I did wire the purple up ... no change or improvement. IVA*: https://www.gov.uk/vehicle-approval/individual-vehicle-approval LEFT Side RIGHT Side LEFT Side Close-Up 2010 Camaro LT1 V6 + MODs (nothing recent to cause this IMO) |
