Old 02-18-2015, 09:00 PM   #1
Steve_ZL1
COTW 12.15.14
Steve_ZL1's Avatar
Drives: 2015 Camaro ZL/8
Z28 Factory wheel offsets?
Please help... Looking for factory Z28 wheel offsets.
Front - 19x11
Rear - 19x11.5
Thanks in advance to anyone who knows the accurate specs...
COTW 12.15.14 Follow my build thread: http://www.camaro5.com/forums/showthread.php?t=384682 AND check me out on Instagram @ZL8CAMARO
Steve_ZL1 is offline   Reply With Quote
Old 02-18-2015, 09:07 PM   #2
X25
X25's Avatar
Drives: '16 C7 Z51
http://www.camaro5.com/forums/showthread.php?t=369676
F 19x11ET11 (25mm further out than 1LE wheels)
R 19x11.5ET26 (23mm further out than 1LE wheels)
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 02-18-2015, 09:31 PM   #3
Steve_ZL1
COTW 12.15.14
Steve_ZL1's Avatar
Not sure this is correct.. Some have said the offsets on the Z28 wheels are
Front +18 and rear +25. So someone is way off. I wish I could get a "100% correct answer... Thanks for the info..
Old 02-18-2015, 09:33 PM   #4
camaro500
camaro500's Avatar
Drives: 2017 Jaguar F Type R Tuned 498awhp
Oh how about the fact the front wheel is an inch larger and the rear .5 inch in addition to the lower offsets. X25 is correct
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller
camaro500 is offline   Reply With Quote
Old 02-18-2015, 09:38 PM   #5
Steve_ZL1
COTW 12.15.14
Steve_ZL1's Avatar
BUT the question still is are the factory offsets correct at +18 and +25 for 100% sure??? Amazing how hard GM makes this info to find
Old 02-18-2015, 10:00 PM   #6
X25
X25's Avatar
Drives: '16 C7 Z51
I have the wheels. The information is correct. It is stamped on the wheel, so not hard to locate, either.
Old 02-18-2015, 11:33 PM   #7
Steve_ZL1
COTW 12.15.14
Steve_ZL1's Avatar
Your post is a bit hard to understand. Can you confirm the offsets please. What you posted reads I think is, +11 front and +26 rear? And these are stamped on the factory wheel.. Any pics of these stamps would be awesome if you have. Thanks for your time and info
Old 02-19-2015, 12:20 AM   #8
X25
X25's Avatar
Drives: '16 C7 Z51
I didn't take a picture, but yes, you read that right. ET is used to denote offset of the wheel. I copy-pasted the info directly from Dropspeed's thread that I've also referenced.
I've looked into your build thread and looks like you already bought Niche wheels. So, what do you plan to do? What offsets do your current wheels have? I've been through various wheels, and I might be helpful.
Old 02-19-2015, 12:55 AM   #9
Steve_ZL1
COTW 12.15.14
Steve_ZL1's Avatar
I sent you a PM..
Old 02-19-2015, 01:12 AM   #10
X25
X25's Avatar
Drives: '16 C7 Z51
I sent you a PM..
Just replied. My only big glaring question is that if you made sure 1LE/ZL1-spec wheels with a 23mm spacer would or would not rub the fender flares. The flares easily go down an inch by the tip, so if you get close to the tip, and use 1LE spec tires (which are 0.8" closer to the fender), and also lower the car on suspension, you might have rubbing issues.
Old 02-21-2015, 11:54 PM   #11
Dr Chill
Dr Chill's Avatar
Drives: 2015 Z/28
I personally measured the backspacing and it does corroborate the front offset is 11mm and rear is 26mm.
2015 Z/28
2019 Porsche Turbo S
Dr Chill is offline   Reply With Quote
Old 08-27-2018, 08:53 PM   #12
aris
Drives: Z/28
Bringing this post up from the dead to correct some info.
The actual correct offset of the 19x11.5 that is stamped on the inside of the wheels is 32.25mm.
The rear wheels on the Z/28 are 19x11.5 et32.25
aris is offline   Reply With Quote
Old 09-07-2018, 09:03 PM   #13
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
some one please take a picture of the wheel stamp and put this to bed please.
TLSTWIN is offline   Reply With Quote
Old 09-07-2018, 10:55 PM   #14
Z28pex
Drives: 2015 Z28
http://www.camaro5.com/forums/showthread.php?t=417722
Z28pex is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
