12-29-2011, 09:25 PM | #1 |
Drives: 2010 Transformer 1SS Camaro Join Date: Nov 2009
Be careful of your tire load index rating especially Nitto Invos P245
I was in the market for new tires and went as far as calling Nitto directly to ask questions. I was really interested in the Nitto Invos. Nitto told me that they are not recommended on the camaro because it did not met GM load index requirements. Load index of the P245-45 R20 (Front stock) is 99W and the requirement by GM is 103 on the front and 106 on the rear. The P275-40R20 meets the 106 for the rear stock size. Nitto said that using an underrated tire could cause damage or even sidewall blistering. When driving at higher speeds this would not be good. Be careful on the tires you get and make sure they meet requirements. Discount Tire even recommended these to me. The computer however prevented the P245 from showing up under the camaro when they tried though. For anyone wondering, I went with the NT05 for the rears and the General Gmax for the front.
12-29-2011, 11:45 PM | #2 |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
I just run 20x9 wheels with 275's all around, problem solved. I run Nitto Invo's or NT-05's, no issues.
12-30-2011, 12:23 AM | #3 |
Drives: 2010 ZL550& 2021 C8 Z51 Join Date: Feb 2010
what does that 99w number mean anyway?
12-30-2011, 12:38 AM | #4 |
http://www.tirerack.com/tires/tirete....jsp?techid=35
This should help.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
12-30-2011, 12:51 AM | #5 |
So-Cal Race team!!
Drives: Tahoe LTZ,2010 2SS/M6 Camaro Join Date: Apr 2009
Bigger Wheels ...and Nitto's 315 on the rear and 275 up front ....I hammer the shit out of them no problem...
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!! |
12-30-2011, 12:54 AM | #6 |
Yeah, I really haven't found many with issues. Especially going 275s all around which have a 106 rating. Each of their tire sizes have different load index. I just wanted to bring this up to those that have or looking at tires in general to make sure the tires are actually rated for the vehicle. Especially on how people out here actually drive their camaros.
12-30-2011, 07:14 AM | #7 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
275 front with 315 rear Nitto Invo is a popular setup with wider wheels and both have a 106W rating. This is the setup I'm going with when my F14's arrive! Maybe your title should have been " be careful of your tire load index rating". This is a consideration to the buyer for ALL tires, not just Nitto Invos. It just happens that the STOCK front size Invos have a lower rating. I got a little nervous when I saw your thread!
12-30-2011, 10:36 AM | #8 |
Sorry about that. I know several people put on stock sized invos all the way around and wanted to be sure I got there attention to make sure they new the potential hazard.
12-30-2011, 07:20 PM | #9 |
Camaro King [^*^*^]
Drives: Apollo 11 Camaro IOM Join Date: Dec 2009
so if im getting 20x9 front 20x10 rear wheels that need 245/45 in the front and 275/40 in the rear i think? but now i see this talk about load that i never even heard about and it seems like every tire combo i look at that i want doesnt work cuz of the load requirement. could you guys help me out plz cuz i dont know how any1 gets staggered stuff with this requirement. im confused lol
12-30-2011, 08:27 PM | #10 | |
http://www.nittotire.com/Tire/invo#size The load index is basically telling you how strong the sidewall is. It is the categorized to a relative weight it can hold. Remember, when you turn a corner, your car will shift more weight to the outside of the turn. So tires can feel more relative weight in a turn then when a car is sitting still. This is what this information is trying to tell you. The front requires 103 and the rear requires a 106. Most tire companies will show the load index on their websites. What do you want out of a tire? What rims do you have?
01-09-2012, 10:05 PM | #11 |
anybody running the stock sizes? if so do you notice any problems
01-09-2012, 11:40 PM | #12 |
Drives: 2011 Synergy Green Camaro LT Join Date: Jul 2011
I've got some scales at the shop. I'm gonna weigh each corner specifically to see how much of a load is on the tires. I doubt there is an actual measurement of 1700lbs of pressure on each tire.
01-10-2012, 10:47 AM | #13 |
"Black Ace"
Drives: Supercharged 2010 SS, 2016 Golf R Join Date: Aug 2008
I'll never buy Invos again for the simple fact that, after only 6K miles of NORMAL driving (no burn-outs or track runs), the tread was gone!? And I thought the stock Pirelles were bad.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq |
01-10-2012, 06:58 PM | #14 |
Drives: 2010 Camaro SS A6 Join Date: Jul 2010
Perfect timing for this post since i just bought these 2 hours ago. On the short ride home from the tire store(also raining) they felt pretty steady. I guess only time will tell. And i have been researching tires for the last month and this is the 1st time i have seen any post related to load weight for the front tires.
