Old 12-31-2009, 06:26 PM   #1
BELLSS
Drives: 2SS/RS 6spM Summit White/Blk-Orng
underdrive pulleys
This question is for the engine builders and tuners , are underdrive pulleys worth the money for a small rwhp gain ?
BELLSS is offline   Reply With Quote
Old 12-31-2009, 06:46 PM   #2
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
if you do a dollar per hp compaired to everything else then yes.
underdrive pully is 200 / 5(hp) = $40 per hp
headers $1200/ 30(hp)= $40 per hp
cai 300/ 15(hp) = $20 per hp
Supercharger $7500(installed)/ 175(hp) = $42.85(per HP)
I can keep going but its not bad
SSTony is offline   Reply With Quote
Old 12-31-2009, 08:49 PM   #3
Camaro21
Drives: SOLD - 2013 M6 ZL1
Has anyone seen a negative effect with installing the underdrive pulley? Overheating, Low Alternator Output, etc.
Camaro21 is offline   Reply With Quote
Old 01-01-2010, 11:36 AM   #4
Badger
Badger's Avatar
Drives: 2010 ABM SS #14 of 2,027
Good Question
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840
Badger is offline   Reply With Quote
Old 01-01-2010, 12:56 PM   #5
liquidfire350
Drives: 2010 Black SS/RS
i had one on my 4th gen, only downside i noticed was low light output (interior and headlamps) at idle
there was also the crankbolt that would sometimes loosen up causing the pulley to move and the belt to come off, but i dont think that is a common issue
liquidfire350 is offline   Reply With Quote
Old 01-02-2010, 06:55 AM   #6
ThunderSS
ThunderSS's Avatar
Drives: 2010 CGM 2SS/RS
NO over heating... I have the SLP Underdrive Pulley. Alternator still maintains the 13V charging... the only problem you may have is over spinning the Alternator..
Just get you a smaller pulley for the alternator... and all is solved..
2010 Camaro SS/RS HKE Forged 416 CID
http://www.fquick.com/ThunderZ28
510 HP/485 Ft. Lbs
ThunderSS is offline   Reply With Quote
Old 01-02-2010, 07:11 AM   #7
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
how could you over spin the alternator with the slp underdrive pulley,, you realize the underdrive pulley spins all the accessories slower than the factory crank pulley.
on some vehicles when you buy an underdrive pulley set they give you a underdrive crank pulley and a smaller (overdrive) alternator pulley to bring the alt speed back up to factory speed,,
the 2010 camaro only gets a smaller crank pulley that spins all the accessories slower, and so far no one has reported that the voltage has dropped enough at idle to worry about an alternator pulley,, but there is no way you will overspin the alternator with a underdrive crank pulley
Old 01-02-2010, 03:31 PM   #8
Bentley78
Rice Cooker
Bentley78's Avatar
Drives: Avalanche Z/71, 2010 Camaro2SS
I dont think its worth spending a couple hundred for just 5hp. I know it adds up over time but you are not going to feel 5hp diff in a 400+hp motor.
I'd rather spend 1k and get a significant upgrade but thats just me.....who knows, im sure i will do this down the road after i get the major things out of the way hahaha
Bentley78 is offline   Reply With Quote
Old 01-02-2010, 03:43 PM   #9
MKS
Drives: SS
its worth it when doing a cam
MKS is offline   Reply With Quote
Old 01-02-2010, 08:06 PM   #10
Camaro21
Thanks for everyone's input.
Old 01-03-2010, 01:56 PM   #11
Bentley78
Rice Cooker
Bentley78's Avatar
I'm not aware of that, can you explain?
Old 01-03-2010, 02:03 PM   #12
Malice
Drives: 2022 Camaro 2SS 1LE M6
I really thought about getting an underdrive pulley, but I opted out of it.
My 2SS is laden with electronics. WHen I'm sitting in traffic with the heat on, wipers going, headlights on, heated seats going, rear defroster on, CD player going, on star working, bluetooth going, etc.... I imagine the alternator would begin to struggle.
My old LT1 stripper was just fine with UDP's, but this car has so many electronics, I don't think I want to stress any systems with voltage irregularities.
2022 2SS 1LE M6
Malice is offline   Reply With Quote
Old 01-03-2010, 02:26 PM   #13
SSTony
SSTony's Avatar
Drives: SS Camaro
I want an underdrive pully but since i will get a supercharger down the road its a waste.
Old 01-03-2010, 02:33 PM   #14
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
I think he meant, it's worth it because you're taking everything apart anyway, might as well swap it in.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 08:25 PM
Texas Speed & Performance 2010 Camaro SS Underdrive Pulley Kit Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 03-17-2012 10:22 AM
Underdrive Pulleys BLT4SPD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 08-16-2009 09:51 AM
underdrive pulleys drayton_cross 4th Generation Camaros 4 06-05-2009 12:04 PM
Underdrive pulleys SSCamaro2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 05-06-2009 04:43 PM
