02-02-2014, 11:01 AM | #1 | |
Drives: 2010 ls3 camaro Join Date: Jul 2013
Whine/Whistle after cam swap
Installed new cam, valve springs, push rods recently everything seemed to go just fine now that i have given it time to break in with very little to no valve train noise difference than stock. Im getting a very annoying whine/whistling noise that increases with rpm and is not present at idle. I have checked for vacuum leaks (just using brake cleaner ) I have also taken off the drive belt to rule out water pump, alt, ps, & idlers. At this point I'm at a loss I have used the search function and found a couple of people with the same problem but the thread died with no fix . I did however find a very similar problem on a c5 that was fixed by swapping the cam out that was just installed. Any advice would be great or if anyone has seen this before??
c5 whine Also cam installed was a lingenfelter gt12 which I believe is a comp cam I did upgrade to a 3 bolt cam gear but kept the stock chain and tensioner (car has 10k) after searching I felt all that was ok to reuse . |
02-02-2014, 11:35 AM | #2 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
Not the intake tube, filter, etc? Thats weird man, always hard to tell where the noise is coming from in such close quarters too
02-02-2014, 11:39 AM | #3 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
Did you do gears at the same time?
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
02-02-2014, 12:04 PM | #4 |
I have installed the intake several different times just to be sure it was not the issue.
Gears are stock and untouched. |
02-02-2014, 12:39 PM | #5 |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
The only things that spin and would make a sound like this IMHO with everything else you've ruled out so far would be one or more of the following:
1) Oil Pump 2) Timing Chain 3) Timing Chain Tensioner 4) Cam sprocket Something related to one of these is my bet! I wouldn't run the car anymore and peel the front cover off to have a look. Are you running a double roller timing set? Did you clearance the pump and cover properly? Stuff like that..
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
02-02-2014, 03:38 PM | #6 |
No double roller timing set and Oil pump was untouched sorry should have said that earlier. To clearance the timing cover I left the timing cover bolts loose and rotated the engine with the crank pulley inside the seal and slowly tightened them as I rotated .. ( Now that you mention it I see the special tool for this ) that might very well be the issue.. I will have to pull it apart and check it out , any other recommended ways to center the front timing cover without the tool ?
02-02-2014, 03:39 PM | #7 |
Drives: G8 Join Date: Feb 2013
Did you change throttle body? Have heard certain throttle body/intake combos whistle. Usually only does it on light throttle.
02-02-2014, 03:52 PM | #8 |
throttle body is stock and has never been off the car
02-02-2014, 03:56 PM | #9 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
Try running the engine with the oil cap off and see if the noise goes away. Did you change any of the PCV routing?
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
02-03-2014, 05:27 AM | #10 |
I will try running it with the oil cap off and see what happens.. I didn't disconnect any of the pcv hoses I was able to work around them .
02-03-2014, 10:41 AM | #11 |
come find out;)
Drives: stockish 2012 camaro ss Join Date: Oct 2012
I have that whistle at light throttle and a local speed shop said it was normal since I re routed the pcv hoses and went with a ptb/vararam.
02-03-2014, 11:02 AM | #12 |
Geek
That sounds like a belt to me. AC belt is the only one left though. It sounds like a belt with a rag held against it.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
02-03-2014, 11:04 AM | #13 |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
IMHO, that is a timing chain or oil pump noise. I would get that stock chain tensioner out of there and use the LS2 chain dampener instead. To me it sounds like a noise you could get from the chain rubbing against the tensioner. What makes my argument a little thin is the fact that you are using the original chain with the original tensioner.
Keep us posted.
Bye bye, Bumblebee!
02-03-2014, 11:32 AM | #14 | |
10-bolt Destroyer
Tags |
whine noise |
