Old 10-17-2011, 10:33 PM   #1
navyblueburnout
navyblueburnout
navyblueburnout's Avatar
Drives: 2010 Camaro 2SS
left rear tire clicking.
I put new wheels on my car a couple months ago and everytime I press on the gas or the brake I hear a click noise coming from the left rear wheel area. I had the place that put the wheels on check it out and they couldnt find anything. I had them do an alignment and tighten the wheels pretty good cause I thought it could be loose and it stopped for a couple hours and came back. Its only does it once when you press on the gas or brake and has a metal clicking sound. Anyone know what this could be?
Proud member of the Never going back to Moderncamaro.com club!
navyblueburnout is offline   Reply With Quote
Old 10-19-2011, 06:41 PM   #2
navyblueburnout
navyblueburnout
bump.
Old 10-19-2011, 06:43 PM   #3
Unknown SSRS
Drives: 2011 VR SS/RS
could be the wheel bearing...my last car did the same thing and it was the wheel bearing..
Unknown SSRS is offline   Reply With Quote
Old 10-19-2011, 06:47 PM   #4
cjordan310
Drives: 2011 LS M6 black
i got the same problem but the sound is come'n from my right front tire! thought it might have been a rock stuck in one of the tires but i got all of them out and it is still do'n it . Unknown SSRS you might be right, chevy service Department here i come lol
cjordan310 is offline   Reply With Quote
Old 10-19-2011, 07:30 PM   #5
navyblueburnout
navyblueburnout
+1 on the sevice department.
Old 10-19-2011, 07:55 PM   #6
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Inspect your e-brake cable to be sure it is not making contact with a TPMsensor. This has to be done with the weight of the car on the wheels.
Old 10-19-2011, 07:57 PM   #7
navyblueburnout
navyblueburnout
Will def. check that in the morning.
Thanks.
Old 10-19-2011, 08:54 PM   #8
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
I had the same issue when I got my new rims and it was the valve stem being too long and it was hitting the ebrake line... switched to to a smaller one and issue gone...
MARINE1991 is offline   Reply With Quote
Old 10-20-2011, 04:57 PM   #9
Chevrolet Customer Svc
Drives: GM Vehicles
Let me know how things go for you two (navyblue and cjordan). Hopefully it's a simple fix.
Jeff Morris, Chevrolet Customer Service
Old 10-20-2011, 05:34 PM   #10
navyblueburnout
navyblueburnout
Just posted another thread about my stems being too long too.
http://www.camaro5.com/forums/showth...25#post3908725
Do you have smaller stems W/ the TPMS attachments or are you just running W/ regular ones?
Old 10-20-2011, 05:35 PM   #11
navyblueburnout
navyblueburnout
Will do
Old 10-20-2011, 05:40 PM   #12
GRYGUSS
Winner
GRYGUSS's Avatar
Drives: 2011 Camaro SS LS3
the inner air nipple is making contact with either the e-brake line or this.....forgive i dint know the name of the part...........(it was making contact just to the left of the bolt. I also used steel circle clamps to hold back the e-brake cable. Hope this helps because it drove me crazy too!!)
GRYGUSS is offline   Reply With Quote
Old 10-20-2011, 05:41 PM   #13
JusticePete
Contact Forgeline. They use a GM compatible sensor that is low profile outside the rim. Problem solved.
Bracket
Sensor on bracket
Rim view
Forgeline Motorsports
3522 S. Kettering Blvd Suite A
Dayton, OH 45439
Phone: 1-800-886-0093
Local: 1-937-299-0298
Fax: 1-937-643-0070
Old 10-20-2011, 05:44 PM   #14
JusticePete
It is more than just a noise issue. The contact between the e-brake cable and the TPMS sensor can damage both parts. With the e-brake cable it will chafe, but before it wears through will cause the TPMS sensor to fail or worse cause your tire to air out. The correct fix is a low profile TPMS.
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 11:00 AM
Bridgestone RE11 Performance Tire Review Info@PeddersUSA.com Suspension / Brakes / Chassis 4 12-28-2009 10:58 PM
