12-19-2022, 06:36 AM | #1 |
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX Join Date: Mar 2011
High boost whipple, but boost drops?
Forged 376 making 20psi on the hit, but drops to 15psi within 1500rpm. Not sure what is causing this, but we’ve eliminated belt slip and started looking toward the bypass valve or other issues.
Anyone else running this kind of boost and have recommendations? 2.75” Griptek upper, 10% IW overdrive and we’re positive the belt does not touch itself
2011 Camaro 1SS
Whipple Supercharged street monster |
12-19-2022, 07:03 AM | #2 |
The ECM can also limit boost. This is an old video of mine, but maybe it'll help.
https://youtu.be/2Y7rPBwQMWg . . . . . .
12-19-2022, 07:27 AM | #3 | |
2011 Camaro 1SS
12-19-2022, 08:07 AM | #4 |
Drives: 2010 Camaro SS Join Date: Dec 2006
I think your onto it with belt slip. I can’t see how the ECM being able to limit boost with a mechanical bypass as you mentioned. If it was happening, my guess would be that it somehow closes the throttle blade down a bit once it senses high boost. Wouldn’t surprise me if the ECM has some setting burried somewhere about that. Maybe check over at HP Tuners forum.
12-20-2022, 10:43 AM | #5 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
An SS car would probably not have that soleniod harness and capability. Also, I just checked my old SS tune, and it shows 37psi in that field you referenced, so 22psi would be the limit, tunewise. I'd be leaning towards belt slip, as its a pretty common problem. There's a user on here called Batman-something with a 800whp whipple. Wonder what his belt setup is.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
12-20-2022, 11:37 PM | #6 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Have you logged your throttle body position? A few had problems with it wanting to suck shut.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
12-24-2022, 09:04 AM | #7 |
Did not think to check that in the logs. It’s a NW 102 that replaced the ported stock TB that was on before. I’ll check this Monday along with pricing on going to an 8 or 10 rib setup.
2011 Camaro 1SS
12-24-2022, 09:49 AM | #8 |
Drives: it changes Join Date: Nov 2010
The ecu has no ability to reduce boost, other than either dumping it ( you say no connection to achieve this ), or by closing the throttle.
So these would be obvious first places to look. But sounds more like belt/slip issues. Why do you think it is not belt related ? And can you check the bypass valve is not doing something strange when it should not be ? |
12-24-2022, 10:21 PM | #9 | |
When I went down to a 3" Griptec 6-rib pulley, I started shredding belts left and right. I made the switch to the Innovators West 10-rib belt drive setup consisting of their 10% OD balancer and a 10-rib 3" Griptec pulley. Now, it makes around 16psi....haven't made it to a dyno yet, but I'm hoping that i'm knocking on the door to 900+..... -Scott |
01-11-2023, 08:55 AM | #10 | |
Drag and Drive is Life
Drives: 2010 Camaro 2SS RS A6 LS3 Whipple Join Date: Aug 2021
16PSI
Wow that is awesome 16PSI on stock is killer you are the man.
My build link... https://www.camaro5.com/forums/showt...4#post11077544
2010 2SS/RS/ Mods, Whipple, 1000cc injector, 102MM TB, Innovation West 10% OD pulley set up 8 rib, AGP twin 450 fuel system w flex on E85, CAI K&N, LT with OR Cats aka no catalytic converters, Coils and wires, 3" exhaust with mufflers, Oil catch can, 2015 ZL1 9.9 3.23 ratio, BMR upper Lower control arms, 15"conversion, BMR Anti Roll Bar 315/60/15 ET street slicks 1972 El Camino SS 565BBC 950HP, All TRZ suspension |
01-11-2023, 08:58 PM | #11 |
Thanks
01-18-2023, 08:17 PM | #12 |
Looks like you guys were right. Belt slip on the crank pulley. Going to the full innovators west setup now.
2011 Camaro 1SS
