Old 05-03-2022, 10:17 AM   #1
Glassman66
Glassman66's Avatar
Drives: 2014 Camaro 2SS/RS 1le
Oil Pump failure lottery ticket winner
So last Friday I start up the car and I got the dreaded 'low oil pressure" warning. Figuring that it was another pos oil pressure sensor I pulled the intake and replaced it on Sunday. Fired it back up, still no pressure.
Towed the car to the shop my business runs out of and put a oil filter pressure gauge and the oil pump is shot.
The car has 19500 miles on it, I've changed the oil every 4500 miles, mobile 1 only and a quality oil filter. This is completely f@cked.
Anyone know a place in the Denver area that can do this job?
I've got a guy at our shop that says he'd do it but he's 2 weeks out and has not done one on an LS3.
The good thing is it happened in the garage and I could shut it right down.
https://www.camaro5.com/forums/image.php?type=sigpic&userid=124840&dateline=15563  941302014 Camaro 1LE SS/RS THE MISTRESS
Glassman66 is offline   Reply With Quote
Old 05-03-2022, 11:56 AM   #2
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
Sorry to hear that, glad it did not happen on the highway. The only shops I can personally recommend are in Colorado Springs or Laramie Wyoming. If you are on Facebook, look up Camaro club of the rockies and ask about trusted mechanics. Good luck.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 05-03-2022, 12:27 PM   #3
Royal Tiger
Drives: 2013 2SS/RS Convertible
Hopefully you’re not replacing it with another pos GM oil pump.
Royal Tiger is offline   Reply With Quote
Old 05-03-2022, 01:33 PM   #4
Glassman66
Glassman66's Avatar
Good idea
Old 05-03-2022, 01:56 PM   #5
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
For this, I would take the handle of a shovel and chase whoever invented these rotary pumps around the car and beat him until I had the last bit wood in my hand
And the next one would be the one who approved it for these engines at GM
Golden oil pumps from 1 gen. SBC!
Heavily damaged, but kept my engine safe.
This bastard has first-class care and will break anyway
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 05-03-2022, 02:51 PM   #6
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
FYI, Melling is our supplier for our oil pumps, they have the contract. Also, working in the field I can count on one hand how many I've seen fail.
NOT A 45 is offline   Reply With Quote
Old 05-03-2022, 04:01 PM   #7
Royal Tiger
Am I mixing the SS and V-6 oil pumps?
Old 05-03-2022, 05:27 PM   #8
Glassman66
Glassman66's Avatar
Ya, I've done enough research to melt my mind on GM LS3 oil pumps. I know melling makes then I'm hoping the higher flow pump will be better.
Old 05-04-2022, 12:31 AM   #9
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I used the melling 10355HV and am very happy with the pressures. I currently have 167k miles and have 32psi @ hot idle, 50-60 psi @ cruising, and 86psi @ wot with the spring that came in it. I tried the high pressure spring at first and my pressure was @ 60-70 psi at cruise with + 90psi at wot. I thought it was a bit much seeing that kind of pressure so I reinstalled the spring it came with because I was afraid that something was going to explode. lol
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 05-04-2022, 01:51 PM   #10
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
10355 is a good HV pump and a direct replacement in the autos. The 10295 is the direct LS3 replacement and high pressure, but not high volume. There is also a 10296 that is HV/HP. Most guys run the 10295 on LS3s unless they have increased the bearing clearances for racing. I have never heard of any of the aftermarket pumps failing and I remember thinking how much it would suck if one of mine went out as I was reading all the threads on it and then it did. Then about 100 miles after the pump replacement, I spun a bearing and now it's 416. but I digress.
The issue is caused by the pressure release valve sticking open which is why you can see it on relatively young engines. I'm not sure what in the aftermarket pumps fixes that, but once you replace it there does not seem to be any further problems with the pump.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
Old 05-04-2022, 01:57 PM   #11
xc_SS/RS
Drives: 2010 Camaro SS/RS
Pretty sure i put the LS6 pump on mine when it failed. More pressure than the stock pump and my stocker went 140k miles. I aint worried
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 05-04-2022, 04:06 PM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I'm running the 10295 Melling in mine as well, with the spring that came in it. I see 39-42 psi at hot idle, and 50-54 cruising at 2k rpms, 65 at WOT..
Old 05-04-2022, 04:32 PM   #13
Glassman66
Glassman66's Avatar
I'm looking at the 10296 with the lower pressure spring. I'm shitting my pants worried that there is internal damage.
It goes to the shop tomorrow I'll get her back in 7 to 10 days.
I've never been in love with a car like this, it's like dating a hot ass stripper.....a ton of fun until the bat shit crazy side shows up, with her pimp and the cops.
Old 05-04-2022, 04:49 PM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I hear ya brother!! It is like that too with mine, it's normal. Hopefully internals are alright!! When mine has been in the shop I'm usually beside myself, can't think, can't sleep just missing the hell out of her and just plain can't function because you don't know, like the last time my converter took a crap and the hub split, thought it was only the converter we had to worry about UNTIL we checked the trans seal and pump housing and found the converter hub wiped out all of that and had to replace it!! So yea, it's like your gal just got taken away from you!! But in this case with our Camaros, you will get her back!!
