Old 08-02-2015, 01:41 PM   #1
scites
Drives: 2010 camaro SS/RS
BAP question
Have a few questions if you guys can help. So last year I installed HFC and a vortech V3si kit on the camaro A6, car ran 12.3@113 on stock 21in wheels/tires. This past friday I installed the 3.47 pulley to raise boost to about 8.5ish, tow links, poly bushings, LCA and drag radials18in.car was maxing out the inj duty over 5800rpm so at 1am I installed a ECS bap, inj duty stays under 80% now. Problem is I went to the track and my AFR is 10.1 at the leanest at WOT pig rich and the car is sluggish. And I ended up running a 13s@105. Didnt think id have to retune after the BAP is this normal? Really made the weekend ďýssapointing
scites is offline   Reply With Quote
Old 08-02-2015, 01:48 PM   #2
scites
one more thing, the ECS BAP has a wire for a Hobbs switch. i didnt hook up a hobbs switch so im assuming if i did it would only richen it up when the BAP kicked on at 5PSI that is if the hobbs switch was a 5psi switch
Old 08-03-2015, 05:18 PM   #3
scites
Anyone?
Old 08-06-2015, 03:32 AM   #4
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Its normal for you to get a little "fatter" or richer when you install a BAP. Your pressure increases, so more fuel. The Hobbs switch is there to activate the BAP. If you wire in your pressure switch wire to be on all the time, that explains why your running fat all the time.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
