Old 10-12-2015, 11:39 AM   #1
scites
Drives: 2010 camaro SS/RS
Horrible times.time for tires
OK so mods are
Vortech V3si ( 9psi)
Ported TB
Hf cats
Flowmaster catback
Poly sub frame bushings
Toe rods
Control arms
Eibach sway bars
Eibach springs
Drag alignment
I am running on stock 21s but I can't give it any throttle at the track as it just spins. Best time on 21s was a 12.6@116 2.6 60ft.
I just ordered 305 45 18 NT05r's and 9.5 wheels. What else do I need to do for traction? I was expecting to at least run a 11.9 on the 21s..sure didn't happen.
scites is offline   Reply With Quote
Old 10-12-2015, 11:41 AM   #2
scites
Looking at the data log I didn't stop spinning and get 100% into the throttle until 4 seconds into the pass
Old 10-12-2015, 12:35 PM   #3
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I've gone 1.51 on this tires. I put them at 20 cold, and do a long M2 burnout.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 10-12-2015, 02:58 PM   #4
scites
I'm hoping to cut at least a 1.6 and see low 11s.header,cam and stall are going in this winter and hoping for mid 10s..
Old 10-12-2015, 03:03 PM   #5
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
Originally Posted by scites View Post
OK so mods are
Ported TB
Hf cats
Flowmaster catback
Toe rods
Control arms
Eibach sway bars
Eibach springs
Drag alignment
If you are losing traction every time, very easily, then you might want to launch with Traction control on.
I switched between TC on and off in my runs and went 11.9 twice with it on, and 12.1, 12.2, 12.3 with me trying to manage the traction.
So, with my small amount of seat time, the computer is better at controlling traction than I am. I hit the button once for the burnout, then turn it back on for the run. I am on stock 20s with normal street tires. My best 60' was like 1.76 I think
Old 10-12-2015, 06:58 PM   #6
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
Wider wheels would help
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
