10-04-2017, 08:07 PM | #1 |
Drives: 2018 Camaro ZL1 1LE Join Date: Sep 2014
TPMS and 2018 ZL1 1LE - HELP...
Hello,
I can't figure this out. I recently installed my old Z/28 wheels and tires which have OEM TMPS in there...they worked perfectly on my 2014 ZL1 and I also have a Orange Electric EL-50448 TMPS relearn tool. I'm hoping that the procedure to relearn is just different and I'm doing it wrong. I started the car, went to the tire pressure section and held the button to put it in relearn mode. Then I went to the sidewall of the drivers side front tire and pressed the button on the tool, nothing happens. No horn beep. Can someone please tell me the procedure to do a relearn on a 2018? And...PLEASE tell me that the problem isn't the sensors for the 2014/2015 cars don't work with the 2018 model... Any help would be appreciated. Thank you. DM |
10-04-2017, 08:35 PM | #2 |
Drives: 2018 ZL1 1LE Join Date: Feb 2009
David,
I had the EXACT same problem this past weekend! I'm using my Z/28 OEM wheels with R7 Hoosiers for the track, after install went to use my reset tool (same one you have) and nada.... Tried it three times, no go. I am concerned that the sensors are in fact different on the ZL1 1LE. Reason I think this is that when it didn't work I recalled that the ZL1 1LE actually also tells you tire temps.....so......I'm concerned that they might be different TPMS sensors. Hope I'm wrong. Can someone clear this up definitively?? Also...David.....got your PM asking about how things went at the track with the Z/28 wheels and the Hoosier R7's this past weekend. Spectacular! Using 315/30/19 on the Fronts and 325/30/19 on the rears and they worked great. The 315's are only slightly (like 3/8") wider than the 305/30 Goodyears. The 325's are slightly (again, about 3/8") narrower than the 325/30 Goodyears. See pics below. Again, this wheel/tire combo worked fantastic at RoadAmerica this past weekend. PM me again if you have any other questions on the tire/wheel combo. Now...back to our regularly scheduled program....what's up with the TPMS Sensors?
2018 ZL1 1LE "RAZECAR" 2016 2SS Convertible "NOTOPSS" (Sold) 2015 Z/28 #306 "ITZFAST" 2010 2SS Coupe "FASSTER" (Sold) 2002 SS/RS "02FASST" (Sold) 2007 Factory Five Racing GTM "REDBLUR" (Sold) "There are two kinds of cars. Red....and everything else!" |
10-04-2017, 08:43 PM | #3 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
There not the same part # I had to buy a set last week when I get in the shop in will post the # For you.
10-04-2017, 09:51 PM | #4 |
Drives: ZL1 1LE Join Date: Oct 2016
It's a different TPMS gents
10-05-2017, 06:32 AM | #5 |
Thanks guys.
Appreciate you providing the part #, Ofer. Will have them changed next time I put on new Hoosiers.
10-05-2017, 08:42 AM | #6 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Pretty sure you need different TPMS sensors.
10-05-2017, 08:58 AM | #7 | |
Dyno Show Queen LOL
Drives: 16 SS & 17 ZL1 Both Yellow Join Date: Jan 2014
Wierd... I took off my ZL1 rims to be powder Coated all I did was install my Wifes stock 16 SS wheels on from her car because she got 1le rims.. I was amazed no stupid light worked perfect even when I went back to my wheels no relearning problems no headaches On my 5th gen thats another story it was the hardest thing to ever relearn the sensors stock or aftermarket.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber |
10-05-2017, 09:15 AM | #8 | |
10-05-2017, 10:26 AM | #9 |
The TPMS on the Z/28 rimes are # 20964159, TPMS on the ZL1LE are # 13598787
10-05-2017, 11:19 AM | #10 |
Drives: '21 ZLE A10 Join Date: May 2012
6th gen TPMS sensors are different. I had to change mine out on the track wheels that I used on my 5th gen ZL1.
10-05-2017, 11:20 AM | #11 |
Oh well, anyone want some Gen5 TPMS cheap?
10-05-2017, 11:40 AM | #12 |
amazon had them...not a terrible price when I purchased...ACDelco 13598787 GM Original Equipment Tire Pressure Monitoring System (TPMS) Sensor Kit with Sensor and Stem. 24.31 each
12-17-2017, 11:36 PM | #13 |
Drives: 2018 Camaro ZL1 1LE Join Date: Apr 2015
How do we reset the sensors when we get new ones? Do we have to buy that tool?
12-18-2017, 06:56 AM | #14 |
Buy the $40 dollar orange tool from Amazon. Sorry, I don't have a link. Super simple once you have the tool, though.
