09-18-2020, 05:45 PM | #1 |
Drives: 2012 Camaro SS Convertible 6MT Join Date: Jun 2020
Quietest differential bushings (not oem)
Hi all,
I currently have a set of differential bushings installed in my car and I’m getting a bit of noise. We suspect they are the cause. Haven’t removed yet but they’re red so I’m assuming they may be bmr pros. Either way, I am reading I can’t install oem bushings back in? Is that true even for a professional shop? If so, is the bmr street the closest to stock or is there a bushing that would be even quieter? Thanks! |
09-18-2020, 09:01 PM | #2 |
Drives: 2011 Camaro 2LT Join Date: Oct 2018
09-18-2020, 09:02 PM | #3 |
Thank you! I’ll check out the thread!
Sounds like Lingenfelter bushings may be quietest? Whiteline up there as well? Any more thoughts? Last edited by DMan918; 09-18-2020 at 09:54 PM. |
09-19-2020, 12:25 AM | #4 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
Does it clunk when you go into gear? Loose bolt... The differential will twist under load and the clunk is the bolt hitting the top of the slotted hole.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
09-19-2020, 07:02 AM | #5 |
Thanks,
No I have a really bad howl from 40mph on up. This is while cruising (very light pedal engagement to keep speed). |
09-20-2020, 02:48 AM | #6 | |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
can you make it howl at will! light acceleration or wot? so far it sounds like a clutch(s) are slipping in the diff,?does it do it with traction control off? try some spray lube on the bushings(don’t know what goes with poly....armor all?) lol, m6 or auto? |
09-20-2020, 07:08 AM | #7 | |
To mention, I know some people would want to come in and say install issue but I feel very confident in this shop and the work done so I really don’t think it’s related to gear setup. I’ll try to get a video today. Thanks for all your help! On edit: Here was something I did question though. Note the movement of the right axel. Is that acceptable or is it not fully seated with the lock ring? No leaks. https://youtu.be/Pb2iHglDQUM . Last edited by DMan918; 09-20-2020 at 08:03 AM. |
09-20-2020, 08:34 AM | #8 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Mentioning the 4.11's to begin with would've been kinda important. You will always get whine with aftermarket stuff. As you mentioned before...gears plus aftermarket bushings....its gonna be noisy. My stock set whines with the BMR diff bushes.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
09-20-2020, 08:37 AM | #9 | |
Thanks. |
09-23-2020, 08:47 PM | #10 | |
09-23-2020, 08:51 PM | #11 | |
Here’s a link trying to show the whine: https://youtu.be/T2fJZraTkOc We’re pretty certain it’s because we installed 4.11s and now the poly bushings are causing all kinds of noise. What may be a minor whine is just escalated into aloud one because of the bushings. The lingenfelter bushings are in order so hopefully that will resolve the issue. Last edited by DMan918; 09-24-2020 at 06:19 AM. |
09-24-2020, 03:10 PM | #12 | |
Drives: Race Car Join Date: Sep 2009
09-24-2020, 03:15 PM | #13 |
Yep exactly. The bushings are doing what they are supposed to. I just prefer quiet at the expense of some diff movement.
