09-21-2021, 12:59 PM | #1 |
2014-2015 Camaro Stealth Splash Guards
2014-2015 Camaro 5th Gen Stealth Splash Guard Kit - Mud Flaps / Mud Guards
(Patent Pending Design) https://www.rpidesigns.com/shop/item.aspx?itemid=3303 This Camaro splash guards kit includes four splash guards, two for the front wheels, two for the rear wheels. No drilling, glue or tape required. These 2014 Camaro splash guards use stock hole locations to mount in combination with providing clips. Best of all - you don't need to remove the wheels on your Camaro! PLEASE NOTE: The rear splash guards will not work on a vehicle with the factory ground effects. If you have any questions please ask. Camaro Splash Guards / Mud Guards Installation: The 2 front splash guards (mud flaps) require the removal and re-installation of 2 screws per splash guard along with a provided clip. The 2 rear splash guards include new screws and spacers for a very simple installation. We provide a screwdriver to remove your screws. These splash guards (mud flaps) are made for the 2014 and 2015 Camaro, they are not a universal splash guard kit. These were designed to follow the body lines of the Camaro and to remain almost unseen. All hardware is included along with the proper screwdriver for a very simple installation. You do not need to remove your wheels to install these Camaro splash guards! These Camaro splash guards/mud guards are also available pre-painted to match your Camaro. Please email us for more information. We now offer these splash guards in a premium thicker material that is twice as thick as our standard splash guards. These offer the ultimate protection for your Camaro. Fitment: 2014, 2015 Camaro https://www.rpidesigns.com/shop/item.aspx?itemid=3303 |
09-21-2021, 01:59 PM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Ordered a set.
09-22-2021, 01:36 PM | #3 |
Thank you for your order.
09-22-2021, 07:16 PM | #4 |
Installed mine last night. Pretty easy.
09-23-2021, 12:24 AM | #5 |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
Picks of mine installed. Paint job is incredible.
09-29-2021, 01:52 PM | #6 |
(Patent Pending Design) https://www.rpidesigns.com/shop/item.aspx?itemid=3303 |
10-01-2021, 08:49 PM | #7 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Would be nice if there were some instructions with the kit. I have the ZL1 fronts and the regular rears.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
07-22-2022, 05:22 PM | #8 |
Thank You for shopping at https://www.rpidesigns.com/shop/item.aspx?itemid=3303
07-23-2022, 10:00 AM | #9 |
Drives: 2014 Camaro 2ss/RS premium sound Join Date: Jan 2014
Does anyOne know if the shipping is UPS, FedEx or PostOffice? (it matters to me)
07-23-2022, 10:32 AM | #10 |
Drives: 2SS/RS Join Date: Sep 2008
07-23-2022, 01:30 PM | #11 | |
One of the options was 55+dollars for 2Dy, but the other was Ground. SP I was thinking the Ground Option could be either. |
07-24-2022, 12:42 AM | #12 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
This reminded me I needed to replace my fronts. Different part on the website but got them ordered. Free ground shipping was appreciated.
07-27-2022, 08:20 PM | #13 |
08-17-2022, 02:14 PM | #14 |
