04-13-2018, 02:48 PM | #1 |
Drives: 2023 Sharkskin Metallic 1LE Join Date: Mar 2018
Harness relocation
I just ordered a set of the MRR 017's with 305/30 for the rears. Do I have to move the harness in the wheel well because of rubbing? Or will I be ok with this size tire?
04-13-2018, 03:01 PM | #2 |
Drives: 2017 Hyper Blue Camaro 2SS Join Date: Aug 2016
305 30 20 should be fine. People run into issues going to 35 series tires
04-13-2018, 04:40 PM | #3 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
305/30 are just fine and no rubbing issues. This is OEM 1LE setup.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
04-13-2018, 05:46 PM | #4 |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
Should we assume all the harnesses are properly routed at the factory?
Always a chance you got the guy who messed it up. So at least you are aware of the issue and check it out when you install. Doesn't hurt to be cautious. Cheers
