Old 04-22-2013, 02:15 PM   #1
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
Question Tips for me with a RWD at the track
My question now is-- how do I launch the car with keep my stock drivetrain in one piece? Should I driver around the water box?
Info on the ride-- LS3 418whp and stock wheels
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 04-24-2013, 11:49 AM   #2
ROD_SS
ROD_SS's Avatar
Anybody?
Old 04-24-2013, 11:52 AM   #3
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
No tips to you.....
Yes you should, there's a wicked thread here about launching these ls3 car. ll about proper clutch slippage. Check the drag forum area.
Caswell239 is offline   Reply With Quote
Old 04-24-2013, 01:39 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
If you have radials front and back, drive around the water.
If running skinnies plus slicks in back, folks will drive thru the water.
If I run skinnies and drag radials, I will go around the water and back up the car into the front part of the water. Doing your burnout on a damp part of the track is much nicer to your differential. When you are done with the burnout, let out of the gas nice, don't keep burning up the tires as you pull up.
I'm not a stick guy so I'm done.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 04-24-2013, 01:56 PM   #5
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Pro Stock John
I have a always burned my tires coming out of the box. Is that killing the tires are just hard on the diff??? Maybe a little of both ??
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 04-24-2013, 02:40 PM   #6
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
if u going to just drive to the track and want to make sure u have a ride back home. then launch off idle, gor around water and just spin the tires to clean them dont need a smoke show.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 04-24-2013, 04:02 PM   #7
Pro Stock John
Writer
Mr. N I try not to sustain the burnout more than a couple feet from the burnout box with a car like mine. I might go longer and harder if I was running big slicks, you might for example burn out past the tree to lay down some rubber if the track isn't hooking.
PROJECT HEAVY CHEVY
Old 04-24-2013, 05:15 PM   #8
Mr. Nasty
Mr. Nasty's Avatar
Ok ill keep that in mind.
