03-18-2012, 12:01 PM | #1 |
LT1FUN
Drives: 2022 LT1 Satin Steel Metallic Join Date: Oct 2007
275/45/20 tires
Hey everyone I have (4) 275/45/20 tires. I would like to know if you can run this size on a 2010 camaro with no issues on the stock wheels. Thanks for your help.
Frances
Bayou State Cruisers |
03-18-2012, 01:53 PM | #2 |
You should be able to , this will give you another 13.7 mm in tire wall , it my trick out the speedometer, not sure about it thou .
03-18-2012, 05:40 PM | #3 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
yes you can use them.....but it will make your speedo off a little......by running 275/45's when your speedo is reading 60 mph....you will actually be running 62.3 mph.
03-18-2012, 05:53 PM | #4 |
Drives: 2SS/RS Join Date: Sep 2008
The only issue I see you will run into is on the front rims. I don't think 275's will fit on the front rims.
03-20-2012, 08:18 AM | #5 |
LT1FUN
Thanks everyone for the help.
Frances
10-18-2022, 07:25 PM | #6 |
275/45/20 for the strip
What are the advantages and disadvantages of the 275/45/20 compared to the 275/40/20 in drag racing bone stock car M6
10-18-2022, 09:13 PM | #7 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
I run 275 40 on the Front and 315 35 on the back. Stock Rims
No problems
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
10-18-2022, 09:31 PM | #8 |
Drives: 2011 Camaro SS 2SS LS3 Join Date: Sep 2022
10-18-2022, 10:03 PM | #9 |
20* 8 on the Front 275 40 20
20 * 9 on the back 315 35 20 no problems
10-19-2022, 10:29 AM | #10 |
Yes you can, but it will pull the sidewalls in a lot. I've seen it done over here, but it is not optimal for the tread contact on the road. A 10 inch wide wheel is better.
10-19-2022, 10:11 PM | #11 | |
That's what I've read everywhere. I've read it would just be better to do what you've suggested, or run the appropriate size tire for that wheel; which, I've read is 285 to 295 depending on the tires. |
10-20-2022, 01:38 AM | #12 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
10-20-2022, 07:19 PM | #13 |
I am running 285/35/20 on the fronts on a 10.5 inch wide. 335's out back on a 11.5 wide.
Similar Threads | ||||
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
Savini Wheels -Beware! | Dr Jkel | Vendor and Seller review / feedback / experiences | 661 | 08-01-2014 06:41 PM |
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow | KILLER74Z28 | General Automotive + Other Cars Discussion | 25 | 07-22-2011 10:51 AM |
All Weather or Winter Tires??? | Plainfield | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 05-18-2010 08:45 PM |
18, 19, & 20" replacement tires ... | dougmac | Wheels and Tires Talk Sponsored by The Tire Rack | 3 | 03-29-2009 05:27 PM |
