09-11-2021, 07:44 AM | #1 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
14 2 SS Splash guard confusion, need some guidance.
So I am looking for some splash guards, My paint is perfect and I have some ZL1 rims coming which will be sticking out further, I also have OEM ZL1 Side skirts coming to install.
Are these the ones I should get? https://www.rpidesigns.com/shop/item.aspx?itemid=3303 https://www.rpidesigns.com/shop/item.aspx?itemid=2233 Is this the same as the 2 above but in a kit? https://www.rpidesigns.com/shop/item.aspx?itemid=2271 Any other options? I see alot for the 10-13 but not 14 and up. I am looking for ones that will not really stand out. Thank you.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
09-11-2021, 03:09 PM | #2 |
Well the last link you posted says they have been discontinued, the set of 4. So it looks like the first 2 links is what you will need for the ZL1 rockers. Theses are the only others I could find. You could always call Phastek and ask if they would work on yours.
https://www.phastekperformance.com/p...uard-combo.htm
09-11-2021, 04:03 PM | #3 |
Drives: 2010 2SS/RS, VR ext/Blk Int Join Date: Jul 2012
This is what I have.
Rear https://acscomposite.com/products/re...aps-for-camaro Front https://www.rpidesigns.com/shop/item.aspx?itemid=2233 The rears are the ZL1 rock guards. I really like them |
09-11-2021, 07:07 PM | #4 |
1JEWLDSSRS Says will not work on 14-15.
CPCNY is there a reason you like those rears instead of the ones from RPIDESIGNS? The ACS ones say 10-13 only as well.
09-12-2021, 06:21 AM | #5 | |
09-12-2021, 07:50 AM | #6 |
I know you didn't say they would, i am just wondering why they all pretty much say 10-13 will not work on 14-15 on the ones I am looking at, I didn't think there was a difference that would affect guards. I'll call them this week.
09-16-2021, 07:50 AM | #7 |
Ordered these, I'll put them on when I install the ZL1 side skirts.
https://www.rpidesigns.com/shop/item.aspx?itemid=2233 https://www.rpidesigns.com/shop/item.aspx?itemid=3303 Hopefully I like them, The GM ones are pretty expensive. I am adding ZL1 Rims and i am nervous about paint chips as currently my paint is flawless.
09-28-2021, 12:55 AM | #8 |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
Pics of mine from RPI.
09-28-2021, 05:30 AM | #9 |
Any tips on The install? No direction sent with them, I haven't taken them out of package yet but figured I'd ask. Do I need to drill?
09-28-2021, 05:55 AM | #10 | |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I've rebuilt a classic Ferrari with minimal documentation so I'm sure I can figure it out, but why should I have to in today's day and age? Did they not take pictures during development? How do they even know they fit? Amazing what just a couple of images or a few words on a page would do to help their customers. This will likely be my only purchase from RPI given their lack of product support. Sent from my Pixel 5 using Tapatalk
09-28-2021, 08:53 PM | #11 |
Larry G I agree with you, I am sure I can figure it out but just a few tips and pic's would be nice. I have purchased a couple items from them and every time I called them it seemed like I was bothering them. Hopefully They hold up.
10-19-2021, 01:46 PM | #12 |
Got them installed, I ended up using another screw towards the top and didn't use their clips or hardware, The screws and spacers they send are way to long, I am also not happy that the front ones are flat black on the wheel side ( Which I like ) and the backs are very shiny towards the wheel side. If I had to do it again I would go OEM.
