03-08-2016, 07:39 PM | #1 |
Drives: 83 el camaro Join Date: Feb 2011
opinion from those not liking the 2016 nose
Planning on updating my 2010 Camaro nose conversion vehicle to more of a 2016 look. BUT not quite.
I like a certain amount of the 2016 look, but the top grille looks to squinty & the lower grille to fishmouth large. Like the headlight look with the drl strips& pretty much like the side vent look. So I figure my version will be something between the 15 & 16 year models, with a taller top grille & shorter lower grille than the new model. Have a 2015zl1 lower grille which I may modify for use with its wrap around lower edge. Also have black stainless mesh grille material. Mine may have a little more of the appearance of this distorted image from Leno's show. [URL=http://s1094.photobucket.com/user/jlcustomz1/media/20151009_201355_zpsfx4y25vj.jpg.html][/UR Any helpful opinions on my line of thought? |
03-08-2016, 08:25 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
How are you going to do the DRL strips and what about the side marker lights would look cool if you could mimic them...
Orange Krush II
03-08-2016, 11:34 PM | #3 |
Drives: 2011 Camaro LS Join Date: Sep 2008
I don't know why the '16 gets hate because I love the look of the '16.
03-09-2016, 06:31 PM | #4 | |
Drives: 2010 Camaro 2SS Join Date: Sep 2015
03-10-2016, 05:49 PM | #5 |
Experimenting with how to make a drl strip in the headlight to resemble the stock one. Making the headlight housing from abs plastic, looking at how to replicate the gear look around the projector also. Probably will get morimoto hid's. Will likely buy aftermarket lower running lights for side grilles. May just buy factory side grilles. Not sure about sidemarkers.
Existing modified 2010 nose conversion. Photoshop concept pic of factory version. |
03-13-2016, 04:12 PM | #6 |
I run 2 catch cans...
Funny how the '16 Camaro now looks like a Scion.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
03-14-2016, 10:40 PM | #7 |
Drives: 2015 Manual Hot Red 2LS Camaro Join Date: May 2015
Damn I knew I'd seen that nose before!! Thank you, yzark99!! Been bugging me since they released the ugly car..
