Old 01-06-2021, 09:04 AM   #1
LS3_JC
LS3_JC's Avatar
Drives: 12’ Chevy camaro SS 6MT
Ebay headers
So i was looking at headers lately and stumbled upon some ebay headers from jy performance, upon seeing them they look exactly like tsp and speed engineering headers and are waaay cheaper, Is this too good to be true or are they legit?
link:https://www.ebay.com/itm/FOR-10-15-C...Cclp%3A2334524
LS3_JC is offline   Reply With Quote
Old 01-06-2021, 10:53 AM   #2
Warship2k15
Drives: 2010 Camaro 2SS
Did you notice that they don’t have the primary tube diameter listed?
Warship2k15 is offline   Reply With Quote
Old 01-06-2021, 11:57 AM   #3
RankSS
Drives: 2010 Camaro SS
Header Inlet / Outlet Size (IN): 1.75" x 2.875"
I'd run em on an econo build.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 01-06-2021, 12:05 PM   #4
Camaro__ss
Drives: 2013 L99
Looks good. They are even set up for adding cats.
Camaro__ss is offline   Reply With Quote
Old 01-06-2021, 04:29 PM   #5
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
There's a reason headers are cheap. They either won't last, fit like crap, are made of inferior materials, have garbage construction, or any combination of all of the above. If you plan on having your Camaro for any extended period of time spend a little extra money and get some budget based Speed Engineering headers.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 01-06-2021, 07:44 PM   #6
Camaro__ss
Drives: 2013 L99
I bought a set of cheap headers on Amazon 2 years ago for about $200. I had to massage the passenger side just a hair with a dead blow hammer, otherwise fitment and finish are fantastic. 30,000 miles later still look great, no rust, no issues. Mine don’t have cats though—just straight to stock exhaust location, so not the same pipes.
Old 01-06-2021, 10:59 PM   #7
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
They are not fully welded on the outside of the primaries connecting the flange. Speed engineering are fully welded. Would not recommend.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Custom 3” With Borla XR1 mufflers and 4” quad tips, B&M deep trans pan, Yank 3400 converter, 3.91s with BMR Delrin bushings, mishimoto 169° Thermostat, Taylor plug wires, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 01-07-2021, 07:54 AM   #8
pyroguy
pyroguy's Avatar
Drives: ABM #831
You say no rust, but you live in a dry climate with no real winter. The OP at least would likely have the potential issue of salt water corrosion living in Florida.
Old 01-07-2021, 09:44 AM   #9
ariZona28
ariZona28's Avatar
Cheap stuff isn't good and good stuff isn't cheap. Some exceptions to this rule but it is a pretty true statement by and large. If I'm going to put time, money and effort into an automotive upgrade I'm going to either buy the best available OR save my money until I can. On a related note I try to avoid Chinese made crap. I know sometimes it's unavoidable during certain maintenance operations but I'll shop around first.
ariZona28 is offline   Reply With Quote
Old 01-07-2021, 02:37 PM   #10
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I used a set of Speed Engineering headers on my truck and I have Stainless Works headers on my vert. There are clear quality differences between the two. I'm not one to pay a ton extra to install the best unless it's absolutely necessary. I can tell you the Speed Engineering headers were acceptable, but not great. They were not as high quality as a set of OBX headers I used to run before I went turbo. I would be afraid to run those eBay headers as you could find yourself with some leaks. If you want to run a SS header at that price, I would look for it on Amazon so it would be easier to return without having to pay return shipping.
On3 kit with downpipe cutout, CTR 76/75, CompCam 239/251 620/632 122+4, and meth. 712whp@5790 717tq@4450 w/15psi boost. Z28 suspension.
Old 01-07-2021, 03:18 PM   #11
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
+1
11.079 @ 122.99mph
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 01-07-2021, 04:35 PM   #12
InFiD3ViL
InFiD3ViL's Avatar
They may be 304 stainless, but how thin are the walls? Also, is there a collector merge spike? Any reviews on fitment? I have a feeling this is where the savings are.
Also, pretty much every set I have seen for these cars run a 3" collector, although I bet 2.875" makes little difference. Some other brands make 1-3/4 inch primaries, but there is power to be had with 1 7/8 or 2". Factor in the slightly smaller collectors WITH the smaller primaries and well, we all know every little bit of power adds up.
If it was me I would spend the extra $100 and get the Speed Engineering. Those are proven good budget headers on tons of builds.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), FlowMaster Outlaw axle back/X-Pipe, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160º thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels - Tuned by Ryan @ GPI via HP Tuners
boltons, ebay headers, headers
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
