Old 03-22-2021, 08:20 AM   #1
MrFolgers
Drives: 2012 Camaro 1lt
V6 Brake Caliper Bolts
It's time to replace my brake pads again. Last time, i ordered what i thought were the correct brake caliper bolts, but they seemed to be either for the SS or ZL1. I checked RockAuto, but they only show the front brake caliper bolts, no rears. Are the front and rear caliper bolts the same size?
MrFolgers is offline   Reply With Quote
Old 03-23-2021, 09:37 AM   #2
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
The mounting bracket bolts? I'm fairly certain that they're the same, but don't quote me. I looked through my chilton manual, and it doesn't give exact specifications on the bolts, but rather the torque specs (and they're the same for front and back mounting bracket bolts)
ElderJ is offline   Reply With Quote
Old 03-23-2021, 09:54 AM   #3
Pearlj10
Drives: 2011 Camaro 2LT
Here’s the part number for a V6 rear: 89027183. If you paste the part number in Rock Auto’s search field, they do stock them for $7.69.
Pearlj10 is offline   Reply With Quote
Old 03-23-2021, 10:02 AM   #4
ElderJ
ElderJ's Avatar
Those are the caliper slide pin bolts rather than the mounting bracket bolts. A lot of guys get those confused, including yours truly.
Old 03-23-2021, 10:46 AM   #5
MrFolgers
Sorry for the confusion. I'm looking for the caliper bracket bolts. I'm pretty sure the rear bolts are the same as the fronts as well. Thanks everyone
Old 03-23-2021, 12:44 PM   #6
KillboyPowerhead
Drives: 2015 Z/22
Caliper bracket bolts are the same front and rear. I priced them out at the dealer and was quoted around $20 each lolol so I just used Loc-tite and a grunt or two and so far so good - been a year and the brakes haven't fallen off yet.
Overkill Tuned; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 03-23-2021, 01:53 PM   #7
redcoats1976
good to know.i cant imagine 80 bucks worth of bolts to work on my brakes.
Old 03-24-2021, 06:00 AM   #8
KillboyPowerhead
Drives: 2015 Z/22
That's $20 per bolt, so $160 for all four corners
Can't believe dealers are allowed to charge what they do for some parts - I was quote $300 (plus tax) for one headlight (RS) bulb! If you priced out the whole car at dealer prices these cars would cost you half a mill.
Old 03-24-2021, 12:30 PM   #9
ElderJ
ElderJ's Avatar
Those guys must be out their ever loving minds for charging $20/bolt.
Old 03-24-2021, 12:54 PM   #10
gtstorey
I think Dorman 14947 will work. About $7 a pair at Autozone, Advance Auto.
Old 03-24-2021, 02:53 PM   #11
swampcritter
Drives: 2014 Camaro LS / 13 zl1
Screaming Chicken may have them.
swampcritter is offline   Reply With Quote
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
