Old 11-29-2024, 11:23 PM   #1
13ZL585
Drives: 2013 SLP ZL585 Camaro
SLP mail slot delete insert instructions
Hello
I am looking for the original instructions for the SLP mailslot delete installation instructions. I have searched this forum, youtube, and even tried using the waybackmachine.com without success.
Thanks
13ZL585 is offline   Reply With Quote
Old 11-30-2024, 04:34 AM   #2
King Nothing
Turning wrenches
King Nothing's Avatar
Drives: 2011 Camaro SS By Berger 11BC21
It’s just tabs that hold it in place. Just push it in and they should pop in place.
Sold-2006 Pontiac GTO
M6 1 of 475
353rwhp 353rwtq
Sold-2000 Camaro SS A4 Hardtop #867 of 8913
1 of 103 Bright Rally Red Hardtop SS A4 in 2000
1 of 25 and only SIM Camaro By Berger in 2011 year, 2011 Camaro 2SS/RS M6 By Berger #11BC21
King Nothing is offline   Reply With Quote
Old 11-30-2024, 08:26 PM   #3
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
The bumper doesn’t need to come out for this? I remember my friend had his bumper out, and did it super easily while the bumper was out, but…
TheBrightSide is offline   Reply With Quote
Old 11-30-2024, 09:29 PM   #4
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Originally Posted by 13ZL585 View Post
Hello
Thanks
I believe you can remove the metal plate under the hood where the hood latches without removing the bumper. Although I have never done this before but there should be access. I could be wrong and hopefully someone chimes in to help you.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 12-01-2024, 12:00 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yes, you can remove the black header plate, just have to remove the screws and plastic pins and pull it out from under the bumper cover. I have done it a couple times to get to the backside of my grille.
Old 12-02-2024, 09:16 PM   #6
13ZL585
What holds the front leading edge down so it is not pulled up by airflow?
Old 12-02-2024, 09:52 PM   #7
SummitWhite11
Drives: 2010 2LT/RS
THIS
2010 2LT/RS
Old 12-03-2024, 10:59 AM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Some screws and push pins hold it all down.. Pop your hood and look at the black metal header plate.. If I remember correctly, the screws hold the plate in place, and the push pins hold the top of the bumper cover down.
Old 12-03-2024, 01:42 PM   #9
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
You are talking about the mail slot delete panel right?? the small one that fits in to the front fascia? If so, those just clip in to place, no need to remove the front end.
MSgt O is offline   Reply With Quote
Old 12-06-2024, 03:14 PM   #10
13ZL585
What holds the very front edge of the SLP panel down? Double sided tape? Something has to be there to prevent the wind from lifting it at speed?
Old 12-07-2024, 08:56 PM   #11
King Nothing
Turning wrenches
Did you try getting a hold of SVE to get the info?
M6 1 of 475
353rwhp 353rwtq
Old 12-08-2024, 09:08 AM   #12
MSgt O
MSgt O's Avatar
Its held in with the tabs, it wont lift out
This right? see the tabs? they hold it in place https://www.camaro5.com/forums/showthread.php?t=435085
Old 12-10-2024, 06:27 AM   #13
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Do you have one? Why are you asking this if you never looked at it? It’s a straight forward process. Buy one, install it. Plain and simple.
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
