Old 11-11-2012, 09:09 PM   #1
LBJ
LBJ's Avatar
Drives: 2012 camaro 1LS. M6
winter storage
I am going to be parking my camaro for the winter. Would it hurt to put the new wheels and tires on now or should I wait until Spring? I don't want to get flat spots on the new tires.
LBJ is offline   Reply With Quote
Old 11-12-2012, 07:18 AM   #2
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
Before you store your car for the winter just over inflate your tires to 50 LBS Psi and you will good with no flat spotting. Unless you have some really cheap tires, flat spotting at normal tire Psi`s with quality tires only last a mile or two. So either leave them as is or over inflate. I myself over inflate.
mickss is offline   Reply With Quote
Old 11-12-2012, 08:31 AM   #3
LBJ
LBJ's Avatar
Thank you .
Old 11-12-2012, 01:13 PM   #4
Blak Widow
Blak Widow's Avatar
Drives: 2011 Camaro SS
I also read somewhere that if u put wood under you tires that helps out too. It had something to do with the moisture on the ground and the difference in temp from the ground.
Blak Widow is offline   Reply With Quote
Old 11-12-2012, 01:14 PM   #5
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
This. I pull my car onto four squares of plywood that I cut for this purpose.
Bye bye, Bumblebee!
Old 11-12-2012, 01:34 PM   #6
LBJ
LBJ's Avatar
my car will be in the garage will that have anything to due with temperature
Old 11-12-2012, 01:48 PM   #7
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
Like they said
Like they said inflate tires to 45-50 psi and I place a tarp (nylon) on the floor that covers the entire foot print of the car plus and drive onto it.This prevents the moisture from coming thru the concrete floor when the garage heat cycles when I warm it up to work out there in the winter and it cools down after.Just a thought.Other than that just make sure you open the garage door each day and take a peek at her to make sure she is all right.You never know.
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
