Old 12-19-2015, 04:07 PM   #1
Devryn17
Suffers Fools Poorly
Devryn17's Avatar
Drives: 2010 SS/RS, CGM w/ Silver Stripes.
How to open car? Wtf?
Ok...took the battery out, closed the trunk, locked the doors, and now I can't figure out how to get back into the car to put in the new battery...help...
2010 2SS/RS, CGM w/ silver stripes. Hurst Shifter, long tube headers, full exhaust, CAI, tune. SAE 407 RWHP/402 RWTQ
Momma didn't bronze my shoes, but when I turned 16 I inherited a lead foot.
Devryn17 is offline   Reply With Quote
Old 12-19-2015, 04:39 PM   #2
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
Put key in drivers door, unlock car.
climb into back seat, pull little loop on the top center of seatback.
climb into trunk, pull emergency release handle.
Many of us have been there and had the same DOH moment.
GVA 45TH 2SS is offline   Reply With Quote
Old 12-19-2015, 05:04 PM   #3
Devryn17
Devryn17's Avatar
The key doesn't appear to unlock the door?
Old 12-19-2015, 05:25 PM   #4
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
[QUOTE=Devryn17;8796683]The key doesn't appear to unlock the door?[/QUOTE
Eddiefuzz is offline   Reply With Quote
Old 12-19-2015, 05:28 PM   #5
Devryn17
Devryn17's Avatar
It just turns to the right. The lock doesn't pop up
Old 12-26-2015, 12:43 AM   #6
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
Call dealer tell them you need a key for your vin made. the key that came with the car was cut wrong
JCunningham is offline   Reply With Quote
Old 12-26-2015, 08:27 AM   #7
xk49
xk49's Avatar
Drives: 2011 2SS/RS L99 RJT Convertible
If you can get into the car you don't have to crawl into the trunk. I just popped the hood and used jumper cables on the engine compartment terminals and then opened the trunk via the button on the door. Been there, done that.
Flowmaster Force II Axle back, Kooks LT's and Highflow Cats, Oracle Side Makers, BC Coilovers, E-Force Supercharger, Rotofab Intake, HexVents, ACS T4 Splitter/Rockers/Wind Deflectors, Aeroforce dual pod, Autometer boost/WB analog gauges, MRR M228 20x10 20x11 Nitto Invo 275/315's, CDC Sport Bar, Tuned by Slowhawk Performance.
xk49 is offline   Reply With Quote
Old 12-26-2015, 01:27 PM   #8
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
http://www.artscyclery.com/descpage-...FQ6Sfgod_MwCSg
Have you ever lubricated your door locks with Triflow? I use the stuff once a year on my door locks, door hinges and door latch, hood hinges and hood release, trunk hinge and trunk lock. It comes with a little red tube that pushes into the key way. Give it a little shot of oil and then work your key back and forth a couple of times. It is in the owners manual where to lube and what to lube. They recommend to use a special GM lubricant. It is made by Triflow. It comes in a Black spray can. Just make sure to shake the hell out of the can.
I really doubt you have a key or lock problem. They just need a little TLC.
Good luck
Dimitri
Dimitrim is offline   Reply With Quote
Old 12-26-2015, 01:59 PM   #9
Badfinger
Badfinger's Avatar
Drives: 2010 2SS
That's strange, the trunk on my Cadillac opens when the power fails and you can't lock it. I thought that was the default on all GM products??
Badfinger is offline   Reply With Quote
