02-13-2021, 09:35 AM | #1 |
Drives: 370z, Srt-6 Join Date: Aug 2017
Zl1 10speed, will it hold gear
Looking to grab a zl1 1le for track/autocross. Curious is anyone auto crossing one of these, will they hold gear in second if you wind it up? Is manual mode and paddles true manual.
Reason I ask, I ran a srt crossfire for a while and even in manual mode to get it to stay in gear for a short straight we had to get a tcu tune. This would cause problems if it up shifted right as we entered a corner I think I would rather get a manual but for the money I’ve found a good priced A10, can anybody talk me out of it? Last edited by Cjw; 02-13-2021 at 09:58 AM. |
02-13-2021, 10:09 AM | #2 |
Drives: '20 ZLE Join Date: Jun 2020
When in Manual mode it will hold any gear even at redline
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. |
02-13-2021, 10:55 AM | #3 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Yep, you can hold it to the rev- limiter.
02-13-2021, 12:23 PM | #4 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
If you enter performance shift mode on an auto by blipping the throttle to the floor, you shouldn't even need manual mode, the car will keep your revs high in the power band and only let go after driving "normally" for a while.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
02-13-2021, 02:09 PM | #5 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
A10 in track mode is as aggressive as it gets, you probably can't do better with paddles unless you're an expert - it's an awesome trans
02-13-2021, 03:06 PM | #6 |
A10 [in Auto mode] in track mode is as aggressive as it gets
'20 ZL1 1LE A10,
02-14-2021, 01:59 AM | #7 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
If you put the car in manual and 2nd gear, it will not upshift. You'll bounce off the limiter with the obvious results.
If you stop the car or slow it to idle (~5 mph?) while in 2nd, it will downshift to 1st and then unlock the converter to prevent a stall, and hold first thereafter. So yes, it will do what you're looking for. But as others have said, full automatic is pretty damn good. |
02-14-2021, 09:50 AM | #8 |
Thanks for all the responses, good to know. I know we’re talking 25 years newer technology but man it was a pain in the ass when you’d throttle down, let up and go to break but the car would lunge forward from the unwanted up shift.
Thanks again all |
02-14-2021, 10:37 AM | #9 |
I find it easier to drive this car around a course in Manual Track because Auto Track will eventually throw-in a few unwanted and unexpected downshifts on you
'20 ZL1 1LE A10,
02-15-2021, 08:43 AM | #10 |
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Dec 2016
I autocross my A10 ZL1 every season since 2017. You will want it in Auto Mode. You will hit the rev limiter otherwise. It would really be hard to avoid the fuel cut out without short-shifting. It shifts so fast that I find those little excursions into third really can help, without the penalty of upsetting the car on downshift or without loss of concentration. The car is much faster in auto. ps. I drive in manual most of the time on the street.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG etc.. |
