10-15-2012, 05:11 PM | #1 |
Drives: the wife crazy talking Camaros Join Date: Aug 2010
ZL1 LSA Supercharger intercooler pump inside look
Part 1 of 2
In my quest to understand how the ZL1 Supercharger works I needed to understand how the intercooler pump functions. The 5 pin interface had me intrigued. So I disassembled and found a microprocessor controlled 3-phase motor with one moving part. It is definitely designed for long term, leak free use. If your pump ever stops working remove the 5 T20 torx screws and inspect for junk lodged in the impeller because there really is not much there to fail. The microprocessor is a PIC33FJ32MC202 controlling the A4935 3-phase MOSFET driver. The IC pump also does not use a mechanical relay to power on. It has an integrated soft start MOSFET switch. Another nice feature with this pump is its ability to detect and report fault conditions back to the main ECM. |
10-15-2012, 05:11 PM | #2 |
Part 2 of 2
Reserved for wiring info. Does anybody know the PED number of the 5 pin female connector that plugs into the IC pump? It should be molded right into the connector. |
01-14-2014, 07:58 AM | #3 |
pin 1 switched source
pin 4 ground pin 5 +12V |
01-14-2014, 09:09 PM | #4 |
Drives: Four Door Camaro Join Date: Apr 2010
I'm curious, do they vary the speed of the pump on the ZL1 or is it always on?
Squash Performance LLC
2010+ Camaro 800 LPH fuel systems |
01-14-2014, 10:57 PM | #5 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
Too much bs right there...they must vary speed
-John S.
01-19-2014, 11:04 AM | #6 |
Emerald Coast Camaros
Drives: 2010 2SS 6m Join Date: Mar 2010
Location: Fort Walton Beach...surrounded by da** pickup trucks I can't see around!
Nice work, thanks!
Procharged F1A-94 on a 416 LSA block, Callies/Manley/Scat/Melling/Cloyes/ARP/Ferrea/Landspeed/Hi-Ram/FIC/Tick/Alky/ Strange/QA1/DSS/BMR/RPS/Tilton/GZM/Fore/AEM/ATi/JGS etc., built/tuned by me and Innovative Street Technologies
'Mo's Seemingly Endless Build Thread |
01-19-2014, 11:16 AM | #7 |
What are on pins 2 and 3? Are they CAN?
01-19-2014, 12:04 PM | #8 |
Drives: it changes Join Date: Nov 2010
very good chance of it, yes.
That way they can control the pump speed, and monitor whether it is working or not I'd think, and if there is a problem, report that back to the ecu. |
01-20-2014, 02:23 PM | #9 |
Drives: Pontiac G8 GXP Join Date: Feb 2011
Andy,
The pump an the ZL1 is not CAN controlled. Both pin 1 and 5 go to a switched 12V power supply in the fuse panel. This pump on the Volt does have output to the ECU This is the pinout on the Volt Pin 1 - Electric Coolant Motor Enable 2 - Electric Motor Feedback Signal 3 - Electric Coolant Motor Control 4 - Ground 5 - Battery Positive Voltage And here is the ZL1 diagram for reference -Greg
1998 Pontiac Grand Prix - 11.24 @ 121
2009.5 G8 GT (Liquid Red) GXP fascia conversion, GXP diffuser 2009 GXP M6 (MSM) #405 586rwhp/495tq TVS2300, CTS-V Fuel System, Cam 222/230 116 lsa, Monster Lever 4 Clutch, American Racing 1 7/8 headers, rear Brembo's w/working Parking brake 11.91 @ 119 Last edited by radrace19; 01-20-2014 at 02:30 PM. Reason: added picture |
01-20-2014, 02:44 PM | #10 |
Ah so they PWM it, that's easier I am just curious what their control strategy is. I'm sure it has more to do with reducing the electrical load than performance but it would be interesting to see.
01-20-2014, 03:01 PM | #11 | |
Dug this info up for you
2009.5 G8 GT (Liquid Red) GXP fascia conversion, GXP diffuser 2009 GXP M6 (MSM) #405 586rwhp/495tq TVS2300, CTS-V Fuel System, Cam 222/230 116 lsa, Monster Lever 4 Clutch, American Racing 1 7/8 headers, rear Brembo's w/working Parking brake 11.91 @ 119 |
12-28-2014, 09:30 PM | #12 |
Drives: none yet Join Date: Oct 2013
Talk about thread resurrection. I've slapped a blower on my 68 Camaro - a ZL1, and have this pump mounted to my frame rail. My computer is from like a 2003 van (so I can have the drive by cable, which I prefer), and there is noooo way it can control this sucker. If I just wanted to have this pump run full steam 100% of the time, is there a way I can hard wire it? Does anyone know?
12-29-2014, 08:30 PM | #13 | |
I posted already pin 1 switched source pin 4 ground pin 5 +12V |
03-01-2015, 02:37 PM | #14 |
I finally have this plugged up to my 68 as per the pinout above. Pump shuts off after about 3 minutes of running, and to restart you have to cut and restore power to the pump. If you restart it enough times, it starts to make a grinding, quacking noise.
I am assuming that there is some sort of built in overheat prevent device and that by just plugging in +12 to pins 1 and 5 and GND to pin 4, it runs so fast that it overheats and shuts down. It seems that the ECU must modulate the speed of the pump, and that having the pump on 100% of the time full blast is not feasible. In short, it looks like I either need a new pump or a way to PWM to pin 3 to run less of a speed. Any thoughts, anyone? |
Tags |
intercooler pump, zl1 lsa supercharger |
Thread Tools | |
