Old 12-25-2011, 11:22 AM   #1
RKCamaro13
RKCamaro13's Avatar
Drives: 2011 Red 2SSRS A6
MPD1 hood with a rotofab CAI ?
Does anyone on here have the MPD1 hood with a rotofab CAI. I just the the CAI for Christmas and I tried to put it on, but it won't fit right. Me and my dad have shaved down the airbox alot and it still isn't fitting right. Is there anyone else with this same problem, if so how did you fix it Thanks
MPD1 Z Force hood, 1LE splitter, ZL1 rockers and diffuser, Heritage grille, Sparks Restorations emblems, Magnuson Supercharger, ID850 Injectors, Alky Methanol Kit, Livernois Fuel Pump Roto-Fab CAI, SW long tube headers, CNC ported throttle body, High flow cats, Lethal Racing Prowler Cam, LS3 conversion, Yank 3400 Stall, Corsa 3" cat back exhaust, RX Catch Can, BMR Suspension, BC Coilovers, Slotted and Cross-drilled rotors, Custom Interior.
RKCamaro13 is offline   Reply With Quote
Old 12-25-2011, 12:59 PM   #2
armyxrays
armyxrays's Avatar
Drives: 2011 2LS All Black Camaro
I had trouble closing my stock hood when I first installed my Roto-Fab. I found I had not seated the airbox into the bottom gromet properly. I almost had to bend the box a little bit (took a little muscle) but I got it in. Check to make sure yours is seated. There is another hole on the bottom of the box that seats into a stud.
Mods: Blacked out bowties, Roto-Fab CAI, Powder-Coated Rims on P-Zeros, MRT 2.0 Exhaust, Heritage Grille, Rear Spoiler, USB Port with Bluetooth package, Lowered 1inch all around, Window Tint, Matte Black hood spears, rocker panels, gill inserts
armyxrays is offline   Reply With Quote
Old 12-25-2011, 01:05 PM   #3
Grimlock
dey see me rollin
Grimlock's Avatar
Drives: the magic school bus
Nope and I was really wondering if I should make a thread about this too. I have the Rotofab and a RK Sport hood.
Grimlock is offline   Reply With Quote
Old 12-25-2011, 01:47 PM   #4
Hollywood2010
Hollywood2010's Avatar
Drives: 2010 SS/RS
you really have to make sure the box is seated on the hole just right. i used a little dishwashing liquid to make it slip on. Be sure to move the lines a little to the left as well and it will fit great with the standard hood. not sure about yours tho. hopefully you didnt shave it down for nothing.
Hollywood2010 is offline   Reply With Quote
Old 12-25-2011, 01:52 PM   #5
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
i can see just from your pic that your hood sits high in the front corner, that would drive me crazy
mikepage0007 is offline   Reply With Quote
Old 12-25-2011, 01:59 PM   #6
Hollywood2010
Drives: 2010 SS/RS
me too. because it sits high in that corner it makes is low in the center
Old 12-25-2011, 02:03 PM   #7
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
In this pic you can see its hitting the stop you can screw them in to see if that is the problem.
Old 12-25-2011, 05:01 PM   #8
Grimlock
dey see me rollin
Grimlock's Avatar
Nah I tried adjusting those screws or w/e. They really don't do anything about lowering the right side, but you can adjust it so the left is lifted a bit so it's symmetrical with the right. Still you then end up with two problem sides as opposed to one. I also shaved my airbox, which helped a bit but the corner still sticks out. Now I'm used to it so it doesn't bother me as much lol.
Old 12-25-2011, 05:08 PM   #9
Cam2011
Cam2011's Avatar
Drives: 2011 Camaro 2SS/RS
Yup, it would drive nuts as well.
Cam2011 is offline   Reply With Quote
Old 12-25-2011, 05:20 PM   #10
montreal2010yellow
montreal2010yellow's Avatar
Roto Fab was design to stick to the EOM hood. If you have an aftermarket with air dam going to the air intake box IMO you might never be able to fit it correctly. because of the whole hood design. Maybe the manufacturor can give you some answers here.
I own a Nickey Stinger Hood which has an air dam with an opening going at the air filter. It brings fresh air directly to the air filter. So since I had a CEL problem with the K&N 6300 CAI (before I installed the Stinger), I reinstalled my G5CR which is an open air filter type. A lot of people don't seem to like G5CR because of the hot air in the engine bay, but with the Stinger I don't have any issues, and I like the looks.
You might have to consider changing you CAI. Check with the manufacturor before....
Name:  P+óques - L'+óme de la Camaro 2.JPG
Old 12-25-2011, 05:38 PM   #11
mike25
mike25's Avatar
Drives: 2012 Camaro 2SS/RS
take a picture of the engine bay directly over the intake looking down at a couple different angles. We can tell you if anything seems to be wrong-
2LT/RS M6 CGM VIN#53104 SOLD
2012 Black 2SS/RS w/ Hurst-
Mods:
Corsa catback, SSE, Vararam
mike25 is offline   Reply With Quote
Old 12-25-2011, 05:40 PM   #12
camarossrs2150
camarossrs2150's Avatar
Drives: abm2ssrs
wow the problems are starting
camarossrs2150 is offline   Reply With Quote
Old 12-25-2011, 05:54 PM   #13
RKCamaro13
RKCamaro13's Avatar
We finally got it to fit, but we had to take a saw and grinder to it, but it is fitting good now, I will take some pictures of it tomorrow sometime.
Old 12-25-2011, 06:01 PM   #14
Eric-MPD1.com
Drives: Cool parts for cool cars
I would think you would be able to make this work out OK. I would think that you would have to take maybe a 1/2" off of the top of the heat shield. If you want give me a call on Monday and i can give you some tips on checking your clearances.
You know that the "Z Force" was designed in conjunction with the CAI inc for an exact fit and hood to airbox seal. Others can work, they just might take some modificatios to do so.
Eric Peters
President/ Mpd, Inc.
765-386-6731(MPD1)
www.mpd1.com
eric.mpd1@gmail.com
Eric-MPD1.com is offline   Reply With Quote
Rotofab CAI 4sale angie7 V6 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 4 11-21-2011 05:19 PM
MPD1 Z Force Hood Install and Painted Stripes showstopper Cosmetics and Lighting Modification Discussions 5 11-09-2011 10:03 PM
Has anyone put on a Vararam CAI and a hood scoop to ram air into it?? mypuppysirius Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 10-12-2011 05:06 PM
***FS: magancharger 2300 with cogs and Rotofab CAI /INSTALLED PRICE ALSO!!!!** east TX Muscle cars Forced Induction 16 08-31-2011 08:52 PM
MPD Z Force Hood and CAI Intake Edlocs Cosmetics and Lighting Modification Discussions 3 02-18-2011 07:13 AM
