#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 02-13-2016, 04:34 PM   #1
Clawson
Drives: 2016 Camaro 2SS
Rear End Fluid Service Notice
Hey all,
Won't be able to give too much detail on this other than what I was told by the Service department at my dealer.
I took it in to schedule my first oil change and to let them know I was hearing an odd noise out of the rear end when doing low speed turns when I first Drive it that day. A rubbing or vibration is best I could explain. Drove with the tech and tried to replicate with no luck. He thinks it's only when the car is still cold. He also mentioned that they had got a service notice regarding certain RPOs of the 6gens where a noise in rear may have to require them to drain the rear end fluid, put new, drive it, drain again, and add new till the sound goes away.
He couldn't remember what specific vins it was on but that they would look at either way when I leave it with them for the oil change.
Clawson is offline   Reply With Quote
Old 02-13-2016, 06:06 PM   #2
jimmypop13
Drives: 2016 camaro ss
This would be new and a good thing as I had the same issue a month ago and dealer had no service bulletin about it. I ended up changing the fluid myself to get the sound to go away
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 02-13-2016, 07:03 PM   #3
MikeyCamaro
Drives: 2015 Challenger SRT
Had the exact same thing in my Challenger. I ended up draining the fluid, refilling with Mobil 1, and the sound was still there so I put in a tube of Trans-X LSD friction modifier. Hasn't made a peep since and it still lays down nice dual tracks. Some diffs just need the friction modifier, so I wonder if that's the case with the Camaro.
Mike
MikeyCamaro is offline   Reply With Quote
Old 02-13-2016, 07:15 PM   #4
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
What was your break in process?
16 Red Hot 2SS A8: NPP, CAI Cold air, Ported TB, Fasterproms Ported intake, E85 flex, Formatto tuned. 11.80@118 with 1.92 60' (600-700 DA) on stock run flats.
jdasnt3 is offline   Reply With Quote
Old 02-13-2016, 07:25 PM   #5
cooley376
Drives: 2016 Camaro 2SS Nightfall
Same problems here.
cooley376 is offline   Reply With Quote
Old 02-13-2016, 07:26 PM   #6
cooley376
Also acts like a locker all the time.
Old 02-13-2016, 08:11 PM   #7
wtcadman
wtcadman's Avatar
Drives: 2013 black 2lt with rs package
Just dropped mine off to the dealer today for this exact issue.
wtcadman is offline   Reply With Quote
Old 02-14-2016, 12:42 PM   #8
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Mine is chattering at low speed turns. I had to get out in traffic quickly so kinda spun the tires while turning and it was like a sound you'd get when it didn't have the proper amount of limited slip additive in it.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 02-14-2016, 08:24 PM   #9
Clawson
I followed the 1500 break in as recommended for the the most part.
Old 02-14-2016, 08:26 PM   #10
Clawson
And wow well glad I'm not the only one then! But yeah I expected to have some issues with a first year car. Still love it and onto regret getting it!
Old 02-14-2016, 08:57 PM   #11
jimmypop13
Mike
I used the stuff recommended in the manual. It has LSD friction modifier already in it. Haven't heard a peep from it since
Old 02-15-2016, 12:40 PM   #12
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Except this is the same as the issue with early Camaro 5's.
Not encouraging.
Rock-It Man is offline   Reply With Quote
Old 02-15-2016, 09:17 PM   #13
laynlo15
laynlo15's Avatar
Taking mine in tm for first oil change at 800 miles. I'm having the service writer to check the vin for the issue you are having
Old 02-19-2016, 05:11 AM   #14
Clawson
Update on my problem... mine wasnt this problem. Basically it wasn't one of the ones listed to have the issue, and after they looked into everything they could think of the sounds could be coming from they are at a standstill on what the issue is. They've contacted GM Engineering and are waiting to hear back on what else they should look for. Haven't had her since Tuesday.
